Author Topic: Image on 899 while running  (Read 6121 times)
Offline luke
  • Unit(s): 998
« on: October 22, 2015, 03:54:34 PM »
I have split the signal from my 899 with the Y cable ...transom transducer and thru hull... What type of image should I expect to see while running. I tried this yesterday and there is no readable image and the depth reading was poor at best. Suggestions?
Re: Image on 899 while running
« Reply #1 on: October 23, 2015, 10:41:56 PM »
Sometimes it's difficult to get the SI xducer low enough on the transom to actually be in the water as the boat comes up on plane ...
Now the issue with erratic depth readings from the shoot thru could be several possibilities ...
If the erratic depth readings are only at higher speed ...the issue is most likely the mounting position of the shoot thru ...
If the erratic depth readings are at all speeds ...the issue could be the mounting positing, the epoxy failing, the AS SIDB Y cable going bad, or a failing shoot thru ...
Is your depth reading issue at high speed or any speed ... ??
Last post March 24, 2010, 01:42:13 AM
Last post May 18, 2010, 12:50:56 PM
Last post January 01, 2013, 12:17:23 PM
by kosmo
Last post February 09, 2015, 02:44:40 PM
Last post May 13, 2015, 12:55:42 PM
by Gimp
Last post August 20, 2015, 12:54:42 AM
Last post October 08, 2016, 10:09:16 PM
by Rpadar
Last post January 08, 2017, 10:58:59 AM
by Kablars
