Author Topic: Helix 12 Chirp SI Combo G1  (Read 10101 times)
Offline zeebeest
« on: December 24, 2016, 01:10:25 PM »
I want to buy a Helix Chirp SI Combo G1.
Is it thrue that the Chirp function only for DI and not for SI works ?
Re: Helix 12 Chirp SI Combo G1
« Reply #1 on: December 24, 2016, 08:33:42 PM »
The only G1 HELIXs with CHIRP are the HELIX 12 CHIRP units (HELIX 12 Sonar , HELIX 12 DI, HELIX 12 SI)... all 3 units only CHIRP 2d ...
In the HELIX G2 and G2N units ...:
*HELIX Sonar units CHIRP 2d ...
*HELIX DI units CHIRP 2d and DI ...
*HELIX SI units CHIRP 2d, DI and SI ...
« Last Edit: December 24, 2016, 08:38:38 PM by rnvinc »
Offline zeebeest
« Reply #2 on: December 24, 2016, 09:18:26 PM »
Thanks for the info .
I am using now a 1198 with 2 HSS tru-hull transducers.
Is it possibile that i use this HSS transducers for the Helix 12 Chirp SI GPS G2 till there is a chirp tru-hull transducer ?
I understand there is no tru-hull transducer for the Helis G2 available on this moment ?
« Reply #3 on: December 25, 2016, 07:19:01 PM »
Yes you will be able to use current 83kHz/200kHz xducers for 2d with the HELIX 12 CHIRP SI GPS G2N ... this would include transom mount, shoot thru fiberglass hull, and true thru hull where a hole is drilled thru the hull ...
Shoot thru fiberglass hull xducer would be XP 9 20 T ... true thru hull where a hole is drilled in the hull are XTH 9 20 brass, XTH 9 20 P plastic, XFM 9 20 plastic flush mount ...
We don't have info on compatible Airmar xducers yet ...
The MSIDB Y cable will be needed with any Setup using a second xducer for 2d ... this cable is not available yet as it is specifically made for the new XM 9 20 MSI T (the Mega xducer shipped with the HELIX 9, 10, and 12 CHIRP SI GPS G2N models) ...
« Last Edit: December 25, 2016, 07:30:40 PM by rnvinc »
Last post November 01, 2015, 11:10:32 PM
Last post January 24, 2016, 09:38:56 PM
Last post April 15, 2016, 02:45:02 AM
by Murre
Last post October 15, 2016, 01:31:44 PM
by scottn
Last post November 06, 2016, 08:03:57 AM
Last post February 01, 2017, 03:20:51 PM
by October1
Last post April 03, 2019, 11:27:28 AM
Last post October 27, 2019, 04:49:01 AM
by reso
