Author Topic: LakeMaster Auto Chart  (Read 14844 times)
Offline jims38305
  • Unit(s): 1197c, Matrix 67
« on: October 19, 2016, 10:59:52 AM »
Just ordered my Lakemaster Auto Chart Pro.  My question is this...once i map an area of a lake and convert it to a readable chart...can i share this new map area with a buddy?
Thanks,
Jim   ;D
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Software: Latest Versions
Re: LakeMaster Auto Chart
« Reply #1 on: October 22, 2016, 08:54:41 AM »
Yes you can, but it is not as easy as copying from one Zero Lines card to another.   I would recommend buying the LakeImages training DVD's to save yourself a lot of aggravation on this process.  There is an entire chapter on how to keep multiple Zero lines cards.   Good luck!
Offline D S
  • Software: 7.5
« Reply #2 on: October 22, 2016, 12:07:48 PM »
yes you can get your buddy to buy his own zerolines card and then simply update it as you would your own within autocharts pro program.ds
stgr
Offline jims38305
« Reply #3 on: October 25, 2016, 02:34:22 PM »
Offline jims38305
« Reply #4 on: October 25, 2016, 02:38:32 PM »
One more question...maybe 2.
#1  I am recording my data to a blank SD card and then taking that info to my computer to change to contour lines.  Is that the way way i am supposed to do it?  Or I am I supposed to be recording to my Lake Master Card or to my Zero Line Card?
#2  When I am done coverting, do I leave it on the SD card, Zero Line Card or do I copy it to the Lake Master Card?
I am real confused...
Thanks for the help.
« Reply #5 on: October 25, 2016, 04:11:39 PM »
Yes .. Record to  a regular SD card.....The ZLC becomes your Lakemaster map card after creating your map with Autochart PC.
Autochart is not intuitive software .... I would recommend getting the tutorial from Lake Images ....They are a board sponsor.  The set of 3 which includes Humviewer and Humminbird PC is a great deal to get you started.
Also, if the body of water you are mapping changes levels throughout the time you are doing recordings....make sure to keep a log of the relative water level.  You can enter that offset when creating the map.  He covers how to do that in the training also.
Offline jims38305
« Reply #6 on: October 25, 2016, 04:40:10 PM »
Offline jims38305
« Reply #7 on: October 26, 2016, 04:47:32 PM »
Do I copy my completed maps to my AC SD Card? or does it do that automatically?
« Reply #8 on: October 26, 2016, 06:29:11 PM »
The Autochart software copies the map to the Zero Lines Card that came with the software.
 I watched the Lake Images training a while back, but haven't actually started using the mapping yet.  You'll save yourself a LOT of hair pulling if you those tutorials.
Maybe do a search for Camohunter's posts.  He did some tutorial posts on here and other forums some time back.  I think he has now moved to another brand sonar and probably has no reason to check in here any more.
Offline fshndude
« Reply #9 on: October 29, 2016, 04:36:43 PM »
I RECOMMEND YOU BUT THEM DVDS I DID BOY WHAT A GREAT HELP. I bought all three. Its nice as you can have both running and switch back and forth as you use you auto chart.  I didn't use a separate SD card, it all went on my zero card. But I am learning.
Dave in Currituck,NC
Offline jermanr
  • Unit(s): 1199
  • Software: checking
  • Accessories: GPS
« Reply #10 on: November 14, 2016, 01:47:05 PM »
Guys, just getting started as well.  Found this thread very helpful especially the tip on the training video's, ordered them right away!
Thanks!!
Rick
Last post August 06, 2013, 06:18:34 PM
by LocDown
Last post July 31, 2014, 07:19:01 PM
by Sledryder
Last post March 28, 2015, 03:02:41 PM
by knrm02
Last post May 12, 2015, 11:37:17 AM
by N9Phil
Last post March 13, 2016, 10:01:07 PM
Last post June 14, 2016, 06:31:56 PM
by N9Phil
Last post November 01, 2016, 05:05:51 PM
by jims38305
Last post May 08, 2017, 11:06:06 PM
