Author Topic: Manual way point entry is not being retained after powered off. Helix 5  (Read 8410 times)
Offline emerald ghost
  • Unit(s): Helix 5
  • Software: do not know
  • Accessories: ball mount
I have a Helix 5 and every time I manually enter a way point it accepts it, BUT when I turn the unit off and then back on. it disappears.
HELP !!
In the waypoint edit menu ...
*Is the waypoint set to "Visible" ... ?)
*Are you in fact selecting "Save" at the bottom ... ??
« Last Edit: July 31, 2016, 10:10:19 PM by rnvinc »
  • Unit(s): Helix 5
Yes, I did all the above.
I have the unit inside the house and without the transducer hooked up.
Wonder if this matters ?
Re: Manual way point entry is not being retained after powered off. Helix 5
« Reply #3 on: August 01, 2016, 06:25:59 PM »
Make sure you are not in demo mode ..... you can turn that off as an option.
You want to be in force simulator mode.
Last post June 05, 2009, 10:32:12 AM
Last post November 17, 2010, 06:42:52 PM
Last post January 23, 2011, 08:57:04 AM
by abraquelebout
Last post February 28, 2012, 02:32:26 PM
Last post April 28, 2014, 10:24:09 PM
Last post April 27, 2014, 05:31:31 PM
Last post June 02, 2014, 10:28:21 AM
Last post February 03, 2017, 09:16:57 PM
