Author Topic: Manual entry of gps position  (Read 9695 times)
« on: February 27, 2012, 12:45:12 PM »
Am I confused or is the only way to enter a manual position is to use the HBPC and the sd card.
On Garmin and Lowrance there is a menu to enter a gps position by the coordinates..
Did I miss that some where in the HB menus..
Offline Double Digit
  • Unit(s): 998 c si...Navionics Platinum +
  • Software: 6.180
Re: Manual entry of gps position
« Reply #1 on: February 27, 2012, 02:57:05 PM »
Chuck there is a way to enter coordinates because I have done it.If I was home I could look but I'm at work.Its under the navigation menu I think...
« Reply #2 on: February 27, 2012, 03:10:47 PM »
I had looked at that and it seems to say that once a waypoint has been created (for however that happens) you can edit the position..(lon/lat..)
I will go try it again..
Thanks...
« Reply #3 on: February 27, 2012, 03:30:28 PM »
More.....
On the unit (1197) the nav x-press menu only has three selections.
cursor to waypoint
save current track
clear current track
The unit is at 5.5 software.
The book that explains this is from the initial purchase and was at 4.?
I guess I dont have an express menu compatable with the book.. :(
This was and still is so simple on Lowrance..
« Last Edit: February 27, 2012, 03:38:11 PM by sonar2000 »
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #4 on: February 27, 2012, 04:00:57 PM »
Chuck yes to can enter them manually go menu menu to Nav down to waypoints curser over you
will see box select create from there you can enter your cord. Gary
« Last Edit: February 27, 2012, 04:09:28 PM by stillbear »
« Reply #5 on: February 27, 2012, 04:24:07 PM »
OK.....I am back in business....
It is a matter of reading the manual and understanding the print.
I was going to the wrong screen.
In a nutshell you guys are right.
Menu....Nav tab,....waypoints...cursor right and create...
Whew..... :P
It was a lot simpler on the lowrance...
And certainly seems easier on HBPC.....
HB is like Garmin.  a lot of thinking needed to make things happen...
But we are making waypoints now...
Thanks guys for all the help....
« Reply #6 on: February 28, 2012, 10:38:56 AM »
OK here is what I learned.
If you want to put in a couple of waypoints do it from the unit.
If you want to put in more than two.  Use HBPC. It is easier that way...
Offline stillbear
  • Stillbear
« Reply #7 on: February 28, 2012, 01:32:04 PM »
Chuck good job glad you got it working ok. Gary
« Reply #8 on: February 28, 2012, 02:32:26 PM »
Thank you guys for all the help and encourgement...
This will really benefit the rescue squad also....
And I learned something..
Is there any question on why this forum is so great.... ;D
Last post June 05, 2009, 10:32:12 AM
Last post November 17, 2010, 06:42:52 PM
Last post January 26, 2022, 03:39:46 AM
by Rüdiger
Last post August 06, 2013, 08:05:18 PM
Last post August 01, 2016, 06:25:59 PM
Last post February 03, 2017, 09:16:57 PM
Last post May 08, 2017, 10:32:00 AM
by Tbonk81
Last post December 03, 2017, 09:07:29 AM
