Author Topic: Heading Sensor?  (Read 9733 times)
Offline sonarbear
  • Unit(s): HB 898cxi SI HD
  • Software: na
  • Accessories: transom mount rod :-)
Heading Sensor?
« on: May 08, 2016, 08:23:41 AM »
Hi
is there a way to add a non - Humminbird heading sensor / compass to the 898 unit? I currently have the regular GPS puck, but would like a dedicated heading sensor for Sidescan mosaics...
Would a regular 0183 compass suffice? Is there such a thing?
Re: Heading Sensor?
« Reply #1 on: May 08, 2016, 10:29:10 AM »
I have read of users connecting a non-Humminbird GPS Antenna to the unit ..but I'm not sure about heading information ...
HB can answer that for certain ...
1-800-633-1468
« Last Edit: May 08, 2016, 10:30:33 AM by rnvinc »
Offline sonarbear
  • Software: na
Re: Heading Sensor?
« Reply #2 on: May 08, 2016, 11:03:16 AM »
The interface for the GPS is NMEA 0183, isn't it? So then, if one can add a second device for NMEA Input, it should work, I guess. I have the Y-cable for the GPS puck, which provides 4 pins, which I suspect are 12 V, GND, NMEAN in and NMEA out. It's from the original bus connector, basically the two voltage pins and the two pins in the middle... Is there a pinout for the second plug on the Y-cable?
Last post March 19, 2013, 04:39:20 PM
Last post May 10, 2013, 01:26:52 PM
by Team CTM
Last post April 14, 2014, 02:49:39 PM
by beertech
Last post May 02, 2014, 10:29:24 AM
Last post March 14, 2016, 09:43:46 AM
by bobcoy
Last post November 08, 2016, 04:48:15 AM
by sonarbear
Last post May 19, 2021, 03:22:08 PM
by ezfishn
Last post April 30, 2026, 09:34:35 PM
