Author Topic: Autochart Custom Shorelines not appearing on head unit  (Read 11824 times)
Offline lancepeterson
  • Unit(s): 999ci HD SI
« on: May 03, 2016, 11:33:27 PM »
Getting my mapping project ready for the season and ran into an issue. I created a wide variety of custom shorelines for a river with outlines for islands etc. Looks great inside of AC Pro but when I load everything on the head unit, a 999, none of the custom shorelines show up only my Lakemaster depth map/layer is there. It's not a huge deal because of the new option allowing for satellite IMG layers & I can convert the Google KML into a Hummingbird track representing the shoreline but I would prefer to have shorelines move over to the ZLC as is, if possible. Am I missing something or is this a known issue?
Re: Autochart Custom Shorelines not appearing on head unit
« Reply #1 on: May 04, 2016, 01:12:53 PM »
FYI, it looks like this is a known issue guys.
Offline D S
  • Software: 7.5
« Reply #2 on: May 04, 2016, 02:33:33 PM »
lance ,,check to see that in
.... settings
...shorelines that you selected:
 use shorelines
 user defind data
DS
stgr
« Reply #3 on: May 05, 2016, 05:46:04 PM »
DS gave that a shot with no luck.   In areas where my data meets the shoreline things are fine, but in areas with no data the shoreline is not outlined.  On another forum CamoHunter mentioned this was a issue.  I would love to see a "fill option" to fill a uncharted water body so the shoreline shows up.
Offline D S
  • Software: 7.5
« Reply #4 on: May 05, 2016, 06:02:39 PM »
lance,
thinking "outside the box"
 could you draw the outline  of the waterbody in question
save in  qgis or similar,,,,, by creating  a color filled poygon
then export as shp file
then import to AC???
or alternatively maybe beter for you.....
 do similar in google earth
 save image...... satellite overlay or colored polygon (whichever u choose)to create as well save as kml
and use the image file as a background  IMG with transparency  within AC
probably a lot of work depends on what u need it for
hope that makes sense
DS
stgr
Last post June 18, 2012, 04:27:37 PM
by Rocktober
Last post June 05, 2013, 01:57:50 AM
by matt@reefmaster
Last post February 26, 2014, 10:58:50 AM
by FlyFisher SLC
Last post June 22, 2017, 09:47:14 PM
Last post August 16, 2017, 09:16:41 PM
Last post March 31, 2018, 05:49:05 PM
by October1
Last post July 19, 2021, 09:40:19 AM
by Lsobo21
Last post April 19, 2023, 12:46:06 AM
by xdive
