Author Topic: Helixg3 mega si head unit clicking sound  (Read 8240 times)
Offline Lsobo21
  • Unit(s): Helix 10 G1 and G3
« on: July 17, 2021, 09:34:10 AM »
I just redid the wiring for my Helixg3 mega si unit with 14gauge tinned wire for the console direct to the battery with 4amp Mel fuse.  Did the Same thing with a helix G1 at the bow.  At the bow voltage on H1 reads same as battery, 12.8 volts. On the newer unit I read 12.1 volts, but checked the pins at the connector and it has 12.8 volts.  Also the head unit is clicking fast for 5 seconds and then slow for 5 seconds.  It is loud enough to hear with no noise around, but easily drowned out if wind or motor on.  Clicking isn’t there on startup screen, only after I clear that screen and then there constantly.
What is causing this clicking or is this normal?  I read that the voltage may be off on the screen, but this seems to much.  Any thoughts?
The reason I made the wiring change is because I was getting a little flickering on mega si when I had higher contrast so I assumed clean power issue because I was using the console fuse block
1775 Impact w/ 115 4-stroke
Helix 10 G3 on the console, Helix 10 G1 on bow
Re: Helixg3 mega si head unit clicking sound
« Reply #1 on: July 17, 2021, 08:55:42 PM »
Clicking in the head unit itself is not normal  ...
Try Restore Defaults  ... if that does make the clicking go away call Humminbird  ...
1-800-633-1468
« Last Edit: July 18, 2021, 09:21:22 PM by rnvinc »
Offline Lsobo21
« Reply #2 on: July 18, 2021, 09:29:10 AM »
Thank you.
I have confirmed the clicking matches the cadence of the transducer.
« Reply #3 on: July 18, 2021, 09:23:36 PM »
Thank you.
Sounds like the transmitter. But I haven’t read any reports of the transmitter creating an audible sound  ...
HB might be your best option  ... 1-800-633-1468
Offline Lsobo21
« Reply #4 on: July 19, 2021, 09:40:19 AM »
Ricky,
Thanks again.  Talked to HB support this morning and the very nice lady on the phone said that hearing a faint clicking like the transducer at the head unit is normal.  She also wasn't concerned that the voltage was off by 0.5 volts between the plug and the display.  She said unless the unit shuts off I should not worry about it.
While I cant argue that unit appears to be working, still leaves me with that hmmm thought process.
Last post June 18, 2012, 04:27:37 PM
by Rocktober
Last post January 08, 2013, 07:45:07 PM
Last post February 26, 2014, 10:58:50 AM
by FlyFisher SLC
Last post September 27, 2015, 10:14:56 PM
Last post May 05, 2016, 06:02:39 PM
by D S
Last post June 11, 2017, 08:12:16 PM
by fshndude
Last post March 31, 2018, 05:49:05 PM
by October1
Last post April 19, 2023, 12:46:06 AM
by xdive
