Author Topic: Helix 5 Settings Save on Exit  (Read 17652 times)
Offline kickingback
  • Unit(s): 899CI
  • Software: Latest
  • Accessories: None
« on: April 27, 2016, 08:33:16 AM »
I just got a Helix5 SI and updated the sostware to 7.30 today.
My question is how do you save your settings once you input them into the unit? When I first tuned on the unit and changed the settings they would not save after turning unit off. I updated and it still does not save the settings. I do not want to have to set the settings every time I go out.
Any help to solve this issue is appreciated.
Re: Helix 5 Settings Save on Exit
« Reply #1 on: April 27, 2016, 04:43:53 PM »
The unit must be operating in forced simulator mode or normal mode (not demo mode).... and make sure the unit is shut off with the power button...not with an external power switch.
Offline kickingback
  • Unit(s): 899CI
  • Software: Latest
  • Accessories: None
« Reply #2 on: April 27, 2016, 05:22:36 PM »
Thanks. I figured it out after rebooting and holding the menu button at start up to select the normal mode. I had not hooked up the transducer as I was testing to make sure it worked.
« Reply #3 on: April 27, 2016, 05:28:38 PM »
glad you figured it out.
« Reply #4 on: April 28, 2016, 01:47:43 AM »
You should disable the Demo Simulator under the Setup tab ...
Last post February 28, 2016, 11:18:38 AM
by Boots
Last post May 29, 2013, 10:49:29 AM
Last post July 09, 2013, 01:44:27 PM
Last post May 29, 2015, 09:41:49 AM
by Thermite
Last post April 07, 2016, 10:27:44 PM
Last post May 23, 2017, 08:28:56 PM
by fshndude
Last post June 20, 2018, 06:19:41 AM
by Dusty-Pants
