Author Topic: old epoxy?  (Read 17332 times)
Offline shorty35
  • Unit(s): Helix 9 SI
old epoxy?
« on: April 26, 2016, 11:29:29 AM »
I just bought a new Helix 9 si. I'm in the process of trying to install it. I have the shoot thru transducer to get on plane reading. I have already knocked out my old transducer. What do you use to get all of that old epoxy off the bottom? I have tried everything!!! Also, when I knocked the old transducer out it seems to have taken a little of the fiberglass with it. Is this a problem?
Thanks!!!
Offline fishreed
  • fishreed
  • Software: current
Re: old epoxy?
« Reply #1 on: April 26, 2016, 12:23:35 PM »
You will probably have to sand it off with a Dremel tool or a hand grinder with sandpaper. Epoxy residue is tough to remove without an abrasive.
Re: old epoxy?
« Reply #2 on: April 27, 2016, 08:39:47 AM »
I checked with a boat rebuilder and he agrees with Fishreed.  Grinder sander but with caution. Take your time and grind in little bits.
Offline shorty35
Re: old epoxy?
« Reply #3 on: April 27, 2016, 09:40:42 AM »
Thanks so much for your responses!!! I got it cleaned out pretty good. I got most of it cleaned out with a dremel tool.
How smooth does the bottom have to be? Meaning... I have it pretty smooth and flat, but there are some ( not sure what word to use) indentions in the bottom. Will this be a problem or will the epoxy go ahead and fill those up?
Thanks!!
Re: old epoxy?
« Reply #4 on: April 27, 2016, 09:55:55 AM »
The epoxy will fill up the cracks.  Just don't overdo it. Take your time. Neatness is 99% of the job.  Heck, take some pictures and post them for us to see..  Might help someone else in the future..
Offline shorty35
Re: old epoxy?
« Reply #5 on: April 27, 2016, 10:07:40 AM »
Ok. I will. Thanks so much!!!
Re: old epoxy?
« Reply #6 on: April 28, 2016, 01:11:46 AM »
Be sure to test the area before glueing ...
Put a bag of sand or similar on the xducer and put enough water in the bilge to cover the xducer and test on the water ...
Offline mike fish
Re: old epoxy?
« Reply #7 on: April 28, 2016, 01:27:25 AM »
X2    I'd test on water before glueing if it was me.
Offline fishreed
  • fishreed
  • Software: current
Re: old epoxy?
« Reply #8 on: April 28, 2016, 02:59:23 AM »
It think that could be classified under the "measure twice cut once"  philosophy. I firmly beleive that when you are trying to find a good place for a transom mounted transducer,  a portable clamp on transducer holder is great way to find the good  "spot" before your start drilling and screwing on your boat's transom.
« Last Edit: April 28, 2016, 04:13:41 AM by fishreed »
Offline shorty35
Re: old epoxy?
« Reply #9 on: April 28, 2016, 09:44:45 AM »
I still need to test it, even though it will be in the exact same spot as the other one?
Re: old epoxy?
« Reply #10 on: April 28, 2016, 11:10:15 AM »
Yes, I would test it before gluing.  You never know what a small change might do...Chuck
Offline shorty35
Re: old epoxy?
« Reply #11 on: April 28, 2016, 11:34:00 AM »
Thanks guys!!! Will do. I won't be able to get it on the water for awhile. I'll take some pictures of my process and let you know how it went. Thanks so much!!!!
Last post April 24, 2010, 02:36:07 PM
by RayinVa
Last post May 01, 2011, 03:49:09 PM
by Roddy
Last post January 20, 2012, 01:51:03 PM
by tboltmike
Last post May 23, 2012, 12:28:14 PM
by LocDown
