Author Topic: Is Loctite 2 part marine epoxy suitable for filling the oversized screw  (Read 15559 times)
Offline C. Corner
  • Unit(s): 798ci SI
holes? I would like to drill the hole out with an oversize bit, fill them with the epoxy and then drill with the correct bit and seal with 3M 4200. Do you think this will work?
Re: Is Loctite 2 part marine epoxy suitable for filling the oversized screw
« Reply #1 on: January 19, 2012, 08:09:20 AM »
It will probably work but I would not bond the screws in place. You might want to remove them at some time...
Offline bigkahuna
  • Accessories: Custom ROV with Imagenex sonar
« Reply #2 on: January 19, 2012, 10:03:47 AM »
I just looked up the spec sheet on Loctite marine epoxy.  It's a fast cure epoxy (not a saturating epoxy) which isn't ideal but is better than nothing.  Another thing you can do is to cut away a small area of the wood core so you can fill in the area with more epoxy.  You might be able to do that with a small dremmel tool.  All you need to cut away is a small amount, maybe 1/8" give or take.  Then mask off one side of the hole and fill the hole (and void) with epoxy (or a mix of epoxy and fiberglass fibers).  When it hardens you can re-drill the hole and mount your hardware.  This way the hole goes through fiberglass - epoxy mix - fiberglass instead of fiberglass - wood - fiberglass.  Hard to explain the process without pictures but if you need a better explanation drop me a line.
Offline tboltmike
  • Cheetah Mike
  • Unit(s): 788ci
  • Software: 5.4
  • Accessories: quadrabeam
« Reply #3 on: January 20, 2012, 01:51:03 PM »
Is this a wood core transom application?
As Bigkahuna stated, best to use a thin slow set epoxy to get wood saturation.
When drilling out, inspect the wood shavings to check for rot, wet or spongy wood.  A pic can be used to probe the wood in the hole for soundness.  If the wood is sound but wet, consider using a syringe to inject denatured alcohol and flush.  The alcohol does a good job in absorbing water.  Use a hair dryer to heat the area to evaporate remaining alcohol.  This cleans and prepares the wood for the epoxy.
Mike
Mike T
Last post April 24, 2010, 02:36:07 PM
by RayinVa
Last post May 10, 2010, 09:15:44 PM
by muskyhunter
Last post May 01, 2011, 03:49:09 PM
by Roddy
Last post July 02, 2011, 12:57:34 PM
Last post February 05, 2012, 09:56:41 AM
Last post March 25, 2014, 01:18:31 AM
by ScottMN
Last post April 28, 2016, 11:34:00 AM
by shorty35
Last post May 29, 2020, 07:39:38 AM
by steelebob
