Author Topic: Helix depth calculations?  (Read 7811 times)
Offline Ikantski
  • Unit(s): Helix
« on: April 23, 2016, 08:03:38 PM »
I noticed my helix 5 SI depths weren't matching the lowrance today. I figured maybe it got bumped to an angle. Switched view to sonar and it was drawing the bottom exactly where it should be. It was doing this pretty consistently in > 50 feet of water, they did match in 5 feet of water.  I had it in 200 (not 200/83).
How the heck does this thing calculate its depth if not by bottom position? Is there a setting that can make it more accurate?  It seems like it must be a software issue as the bottom drawing is accurate.
http://i.imgur.com/vDVEOp7.jpg
http://i.imgur.com/hJE2JPD.jpg
Note: It does have the latest firmware update.
Re: Helix depth calculations?
« Reply #1 on: April 24, 2016, 11:50:12 AM »
Erratic depth readings can often be attributed to 2 sonars running at the same time ... I've even seen this issue when the 2 sonars are running on separate frequencies ...
You might try shutting off the Lowrance, Restore Defaults and test ...
Last post July 29, 2010, 03:55:06 AM
by gobio
Last post May 19, 2015, 12:07:30 AM
by CATNIP
Last post April 20, 2016, 10:04:42 PM
Last post July 19, 2017, 07:40:30 PM
by tschultz
Last post July 13, 2021, 10:06:38 PM
Last post June 16, 2023, 08:10:41 PM
Last post June 27, 2023, 09:07:12 AM
by oschi
