Author Topic: Water Turbulence Effect on Transducer  (Read 7321 times)
Offline 95Ranger
  • Unit(s): 717
« on: April 18, 2016, 10:08:47 PM »
The MinnKota trolling motor has the skeg on the front of the motor. If a Helix 10 SI transducer is mounted right behind the skeg, will the water turbulence from the skeg reduce  the quality of the side images and down images?
95Ranger
Re: Water Turbulence Effect on Transducer
« Reply #1 on: April 18, 2016, 11:27:28 PM »
It would be very unlikely that the TM skeg would cause water turbulence to the extent of degrading the imaging ...
You could test this yourself by making a snapshot of recording of the xducer an and off the TM ...
I have seen turbulence from a TM on high speed as the bubbles pass by the transom mounted HDSI ...but that turbulence would be from the TM prop ...
« Last Edit: April 18, 2016, 11:29:33 PM by rnvinc »
Offline 95Ranger
  • Unit(s): 717
« Reply #2 on: April 19, 2016, 09:25:36 PM »
Thanks for the reply. I wanted to make sure that this was not going to be a problem before I purchased a MinnKota trolling motor with the skeg on the front.
95Ranger
Last post September 08, 2010, 01:26:41 PM
by reddog
Last post April 25, 2011, 10:57:06 AM
Last post February 25, 2013, 04:03:08 AM
by junoir
Last post June 06, 2013, 03:43:03 PM
by Amphib206
Last post July 03, 2013, 12:48:11 PM
Last post November 25, 2013, 09:58:08 AM
by steelebob
Last post March 12, 2014, 01:12:41 PM
by Bayou Basser
Last post April 29, 2015, 12:17:16 AM
