Author Topic: Can I take transducer out of water while the unit is ON?  (Read 11685 times)
Offline CHOOhonets
  • Unit(s): 998 HD SI
  • Software: 6.49
  • Accessories: AS SI LR Y cable
« on: April 25, 2011, 02:43:49 AM »
Can I take transducer out of water while the unit is ON? As far as i know you shouldn't do it with Raymarine products without turning the unit OFF because it can causesome troubles with the transducer.
PS I am asking because when I use my unit (transom mount, portable clamp) at inflatable boat and go high speed it is better to lift the transducer up to reduce pressure on the clamp and the transducer and to reduce flowing and splashing caused by the clamp.
Re: Can I take transducer out of water while the unit is ON?
« Reply #1 on: April 25, 2011, 09:11:31 AM »
Yes it is ok to take the transducer out of the water while power is on.
Offline mendota
  • Unit(s): 1197
  • Software: 4.75
  • Accessories: AS-GRHA
« Reply #2 on: April 25, 2011, 09:39:30 AM »
I just noticed that the latest version of software has added "turn sonar OFF" to the shutdown menu, so now there is a quick way to turn the sonar off when not desired.
« Reply #3 on: April 25, 2011, 10:57:06 AM »
Great for when you just want to run GPS/NAV.   Way to go HB..
by Sonshine Fishing
Last post September 08, 2010, 01:26:41 PM
by reddog
Last post April 29, 2011, 09:29:42 PM
by xSilmarilSx
Last post February 25, 2013, 04:03:08 AM
by junoir
Last post March 12, 2014, 01:12:41 PM
by Bayou Basser
Last post February 13, 2015, 09:43:07 PM
by jworks
Last post May 06, 2015, 01:21:16 PM
by KJ
Last post April 19, 2016, 09:25:36 PM
by 95Ranger
