Author Topic: Bottom Hardness Question  (Read 14653 times)
Offline d.sonnenburg
  • Unit(s): 898C SI, 998c HD SI
« on: March 01, 2016, 09:33:21 PM »
What would be the harder bottom on the scale, 5 (blue colors to the left on scale) 33 (red colors to the right)?
Also what does the gain adjust?
Re: Bottom Hardness Question
« Reply #1 on: March 02, 2016, 02:15:29 AM »
You might also post your question here while waiting for someone with AutoChart experience ...
http://autochart.forumotion.com/
Offline CamoHunter
« Reply #2 on: March 04, 2016, 09:49:50 AM »
In your bottom hardness map, I would presume the blue areas are soft bottom, the green areas harder bottom, and the yellow areas harder yet, and the red areas very hard.  Just saying that because of the progression of color, and how it relates to the deep bottom area, and all the harder bottom areas are associated with points, shore, and looks like a big rock hump in the middle.
« Last Edit: March 04, 2016, 10:25:31 AM by CamoHunter »
« Reply #3 on: March 04, 2016, 10:10:15 AM »
Thanks for poppin in camo ...
It really helps these guys with the mapping questions that I don't have experience with ...
Offline 35wailin
  • Unit(s): Helix 7 SI
« Reply #4 on: June 22, 2017, 10:47:23 AM »
I agree with Camo, based on recent mapping I did on a known bottom hardness area, the zero end of the scale is soft and the higher( right side) is harder.
I have no idea regarding Gain, as I am just starting to learn this as of a month ago.
Offline Oilpig
  • 2007 Ranger Z21, 250HP HPDI
  • Unit(s): 787c2, 997c SI
  • Software: 5.4 on 787c2, not su
  • Accessories: None
« Reply #5 on: July 21, 2017, 07:38:30 PM »
The red bit down the middle is likely not a rocky hump.  If you compare it to a depth map I'd be willing to be it's the creek/river channels.  Despite lakes being full way above the channel banks, current still moves within the old channel (generally due to differences in density of the water column).  Because of this you may be seeing the hardness increase in the channel because the muddier (softer) bits are sorted out by moving water leaving the denser material behind.  Storms on the lake will mix material up the water column as well, again with denser/harder bits settling into areas where currents keep the smaller stuff moving around until it finds a calm spot.
Great image by the way!
"Them that don't know him won't like him and them that do sometimes won't know how to take him" - W. Nelson & M. Haggard
Last post July 11, 2013, 09:40:37 AM
Last post August 09, 2013, 03:27:35 AM
by matt@reefmaster
Last post May 05, 2014, 12:21:15 PM
Last post May 29, 2015, 10:27:37 PM
by d.sonnenburg
Last post July 30, 2015, 12:44:48 AM
by D S
Last post September 08, 2015, 02:41:35 PM
by D S
Last post December 13, 2016, 09:39:58 AM
by D S
Last post March 16, 2018, 01:00:02 AM
by October1
