Author Topic: btype bottom hardness  (Read 8333 times)
Offline d.sonnenburg
  • Unit(s): 898C SI, 998c HD SI
« on: July 28, 2015, 04:56:45 PM »
Can someone explain to me how btype settings work? What should my max be? What is the harder bottom 0 or 150?
Offline D S
  • Software: 7.5
Re: btype bottom hardness
« Reply #1 on: July 30, 2015, 12:44:48 AM »
d...
 once you calculate a map in bottom hardness
 then press the up and down arrow (find depth Range) this will give u a upper and lower range number
 use this formula for the gain
100 divided by the upper range number
(ie) say upper range is 50
100 divided by 50 = 2
this will be your gain
set fresh or salt water
set gain
set desired color
if u check 2d color layering then u can use the sliders on side of map to adjust transparency to see difference in two layers
ds
stgr
Last post July 11, 2013, 09:40:37 AM
Last post August 09, 2013, 03:27:35 AM
by matt@reefmaster
Last post May 05, 2014, 12:21:15 PM
Last post May 29, 2015, 10:27:37 PM
by d.sonnenburg
Last post September 08, 2015, 02:41:35 PM
by D S
Last post July 21, 2017, 07:38:30 PM
by Oilpig
Last post December 13, 2016, 09:39:58 AM
by D S
Last post March 16, 2018, 01:00:02 AM
by October1
