Author Topic: readouts  (Read 7389 times)
Offline tblshur
  • Unit(s): 798ci hd si
  • Software: 7.120
readouts
« on: February 10, 2016, 09:46:00 PM »
are there just certain pages or screens that u can put readouts on :)
Re: readouts
« Reply #1 on: February 11, 2016, 11:03:56 AM »
Numbered series legacy units have the white data boxes ...such that the Readouts are selectable under the Setup tab and down to "Select Readouts ...
(Some of the data boxes are not changeable in the NAV/Chart views) ...
800 and 900 series SI units can turn off the data boxes under the Sonar tab and down to "Readouts Off" and have depth/temp overlayed onto the full screen SI view....
1100 series units can turn off the white data boxes completely ...
HELIX units have the above options and the added option of turning off the Readouts under the Setup tab and down "Select Digital Readouts" ...
ONIX has more customization of data than numbered units or HELIX units ...
Which unit do you have ... ??
« Last Edit: February 11, 2016, 11:05:45 AM by rnvinc »
Offline tblshur
  • Software: 7.120
Re: readouts
« Reply #2 on: February 11, 2016, 11:28:34 AM »
thanks rivinc ,sorry, i have 798ci hd si. i wanted temp and voltage on some of the pages , but could not get them they work good on some pages.thanks again.
Re: readouts
« Reply #3 on: February 11, 2016, 09:49:06 PM »
Some of the data boxes in the NAV views are hard coded (even tho you can change the selection in the Readouts menu) ...
I'm not sure which boxes are hard coded in the 798 ... COG I'm sure ...
Here is the page from the 798 manual ...
Last post January 07, 2015, 07:53:53 PM
Last post April 30, 2012, 10:07:28 AM
by Shooter00
Last post February 28, 2013, 11:21:45 AM
Last post April 22, 2013, 09:40:51 PM
by easysailor
Last post March 19, 2014, 11:37:27 AM
Last post June 18, 2014, 09:20:31 AM
by Donhasley
Last post August 14, 2014, 01:09:38 PM
Last post July 14, 2018, 12:15:38 PM
