Author Topic: How to get temp in one of the readouts?  (Read 6683 times)
Offline Rotus623
  • Software: 6.49
« on: March 18, 2014, 09:41:09 PM »
I dont use the readouts with SI, but I do with 2d, chart, and the 2d/SI blend. Is there a way to display temp in any of these boxes? The only screen where I can get water temp from is the full SI screen. Underneath is a photo of where Id like to add temp, but there doesnt seem to be an option to do so, at least not in SIM mode.
Also, where is the sonar noise filter in the menu. I know Ive seen it before but cant seem to relocate it.
Re: How to get temp in one of the readouts?
« Reply #1 on: March 18, 2014, 10:13:55 PM »
The temp cannot be set to a readout box when the unit cannot detect an xducer...(I'm assuming no xducer is attached being you mention you are in Simulator)..
Power the unit in Normal or Simulator with a xducer attached and you will be able to apply the temp readout...(it doesn't have to be in the water to do this .. It may even show the correct temp where the xducer actually is)...
« Last Edit: March 18, 2014, 10:45:10 PM by rnvinc »
Offline Rotus623
  • Software: 6.49
« Reply #2 on: March 19, 2014, 07:16:04 AM »
Thanks!
« Reply #3 on: March 19, 2014, 11:37:27 AM »
The Noise Filter menu is under the Sonar menu tab.  Your unit will have to be running in the “Advanced” User Mode menu setting to see it though (User Mode menu is under the Setup menu tab).
Last post April 30, 2012, 10:07:28 AM
by Shooter00
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
Last post February 28, 2013, 11:21:45 AM
Last post April 22, 2013, 09:40:51 PM
by easysailor
Last post June 18, 2014, 09:20:31 AM
by Donhasley
Last post February 11, 2016, 09:49:06 PM
Last post July 14, 2018, 12:15:38 PM
