Author Topic: Couple Questions  (Read 9313 times)
Offline TRX
  • Unit(s): 999
  • Software: 7.650
Couple Questions
« on: December 13, 2015, 01:53:22 AM »
1. Im mounting a Shoot thru hull transduce for my 999 and the helm. I was told to put water in my bilge and test. Well the issue is my 2015 Triton does not like water in there and the bilge kicks on. Would it be feasible to stick the duce in plumbers putter temporarily just for testing purposes at high speeds? how easy is plumbers putty to clean up once dried?
2. I want to put a Helix 9 GPS/Sonar only at the helm just for the mapping and 2d and use the 999 for SI/DI. Does the helix 9 use the same ducer as the 999 and can they be connected?
Offline jabsy
  • Unit(s): 898si, 859di
  • Software: 7.20
Re: Couple Questions
« Reply #1 on: December 14, 2015, 05:48:37 AM »
1. Why dont you just disable the bilge for your testing? Take out the fuse or something simple?
2. Dont see why not, the Helix should be able to take the 83/200 from the HDSI transducer attached to the 999. My 898 and 859 share all sorts of frequencies on each screen.
Born to fish, forced to work
Offline TRX
  • Unit(s): 999
  • Software: 7.650
« Reply #2 on: December 14, 2015, 12:21:02 PM »
I foumd where the fuses ara. Thats what I im goin to do. While testing whats the best way to hold the transducer in place
Offline jabsy
  • Software: 7.20
« Reply #3 on: December 14, 2015, 04:32:38 PM »
You just want to make sure there are no bubbles, a good big blob of silicone would do the job, covering the whole underside of the transducer. You should be bale to peel this off afterwards. is there no "pot" in the boat from factory to fill with water and store the transducer?
Offline TRX
  • Unit(s): 999
  • Software: 7.650
« Reply #4 on: December 14, 2015, 05:57:41 PM »
Not that im aware of. Im going to have to test fit spots
Last post April 14, 2010, 02:56:18 PM
Last post September 18, 2010, 04:02:05 PM
by tierce2008
Last post February 07, 2011, 11:20:42 AM
by Kimi
Last post December 19, 2012, 05:08:26 PM
by strawdg
Last post November 12, 2013, 10:55:45 AM
Last post June 11, 2014, 05:32:17 PM
by lowerunit
Last post July 07, 2014, 10:43:13 PM
by CarolC
Last post September 28, 2017, 09:50:26 PM
