Author Topic: couple of questions on new installation  (Read 11267 times)
Offline riven1950
  • Unit(s): 798ci si
« on: April 10, 2010, 11:43:59 AM »
Just installed mt 798ci si and about ready to put it in the water to test. Two questions:
I have a separate instruction page for a transducer insert. Is this something that is used if you lock down the transducer or is it for all installs? Is it needed before testing? What purpose does it serve?
Can anyone direct me to some concise instructions on how to record screens while I am using the unit?
Guess that was more then one question...but all replies are appreciated.
Ted
Offline riven1950
  • Unit(s): 798ci si
Re: couple of questions on new installation
« Reply #1 on: April 10, 2010, 11:45:39 AM »
PS: I did successfully update my software version already.
Ted
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #2 on: April 10, 2010, 02:35:44 PM »
Question 1 have no  idea what your talking about Question 2 insert blank sd card prefer 3 gig
fast card.Go to views screen curser over to snapshots an recorder turn on recorder while your
there might want to enable snapshots. exit and you can record or take a snapshot which
ever.Note while you are recording snapshot won't work. To stop rec. just hit menu and hit
stop .   Gary  PS I use a 4gig extreme 111  card
Offline riven1950
  • Unit(s): 798ci si
« Reply #3 on: April 10, 2010, 05:21:32 PM »
Thanks ...I will pick one up. In the meantime will a 2 gig work but maybe not store as much?
TR
« Reply #4 on: April 10, 2010, 06:44:12 PM »
Yes 2g will work fine.  you want to keep recording small possibly 15 minutes or less. that will take about 20,000 Kbytes of storage.  Which leaves room for more.  The reason for small (time) recording is data transfer from unit card to PC and the viewer loading time.  Chuck
« Reply #5 on: April 14, 2010, 02:56:18 PM »
Ted,
The separate sheet of instructions should be for the lock-down screw that most do not need to install.  It keeps the transducer from kicking-up and so the transducer is more likely to be damaged if you were to hit something when you install this extra screw.  Do to the speeds that some boats are capable of this screw will need to be installed.
Last post September 18, 2010, 04:02:05 PM
by tierce2008
Last post February 07, 2011, 11:20:42 AM
by Kimi
Last post December 19, 2012, 05:08:26 PM
by strawdg
Last post November 12, 2013, 10:55:45 AM
Last post April 24, 2014, 04:36:22 PM
Last post July 07, 2014, 10:43:13 PM
by CarolC
Last post December 14, 2015, 05:57:41 PM
by TRX
Last post March 05, 2018, 06:12:01 PM
by Ketchup
