Author Topic: 998 and 999 power draw effects  (Read 9944 times)
Offline fishbone
« on: October 23, 2015, 08:26:08 AM »
I have run a 998 SI off the starting battery without any problems for 5 years.
Several of the lakes I fish are electric only, so the engine never gets started to aid in charging.
A new 999 SI replaced the 7xx unit on the bow so that two 99x units are drawing on the starter battery.
Now my stater battery drops from 13.2 v to 12.3 over the course of 6 hours.
I would expect the drop to be less if the engine was used.
Does anyone use a different approach when using heavier draining units?
2013 Stratos 189 VLO
E-Tec 150 HO 150hp, 6" JP
80# Fortrex, 2ea 8' Power Poles
HB 998cSI @ Console, HB 999HD SI @ Bow
Offline Ronquest
  • Unit(s): 999 1159
  • Software: 1.60
  • Accessories: 360 Terrova 112 I-pilot
Re: 998 and 999 power draw effects
« Reply #1 on: October 23, 2015, 11:38:54 AM »
If your battery is in good condition you shouldn't have any problems.  I've run 2 units (wired like yours) and a 360 for that time frame and didn't have starting or unit issues.
-Do you need to have both units running all the time?
-Carry jumper cables on the boat, if you need to, jump to a trolling motor battery.
-Turning down the brightness of the screen, and turning off the transducer that's not being used will save energy too.
Offline fishbone
« Reply #2 on: October 23, 2015, 01:05:12 PM »
Thanks Ron. I had a 3 position switch installed when the boat was new that puts the engine starter on either the engine battery or one of the trolling motor batteries.
I was just surprised at the drop in the charge from the 2 HB.
« Reply #3 on: October 24, 2015, 04:08:15 PM »
6 hours for 2 900 series units should be about 12AH in 6 hours....They each draw about an amp.  It shouldn't be that much different than 1 700 series and 1 900 series.
Last post November 10, 2009, 12:04:39 PM
Last post January 16, 2010, 08:35:25 AM
by dybvad417
Last post May 12, 2011, 04:40:14 PM
by depark1
Last post October 03, 2014, 06:24:37 PM
