Author Topic: Current draw on 997c SI unit  (Read 10377 times)
tonyr
  • Guest
« on: November 09, 2009, 07:38:34 PM »
I am in the process of upgrading from an older Matrix unit to something like the 997. Looking at the specs, I cannot see what the amps draw might be for a proper chartplotter plus SI function. I assume it is much more than the little Matrix, but  just how much is the question.
I have a 50 h.p. Yamaha, and it has perhaps 6 amps available. Is this enough?
Thanks, Tony.
Re: Current draw on 997c SI unit
« Reply #1 on: November 10, 2009, 12:04:39 PM »
According to the Humminbird web site the 997c Si unit draws about 800mA.
http://www.humminbird.com/support/FAQ.aspx?faqid=499
Your motor can provide about 5.2 Amps more than what the 997 unit will need, so you are good.
[1,000mA (milliamps) = 1.0 Amps]
Just be sure to use the heavier gauge power cable that comes with the 997 unit when you install it.
Last post March 10, 2010, 01:50:46 PM
Last post August 26, 2010, 01:56:54 AM
by ElvisMarcy
Last post September 29, 2010, 04:45:07 PM
Last post June 06, 2011, 10:45:08 AM
by Roddy
Last post December 13, 2014, 04:38:44 PM
Last post October 24, 2015, 04:08:15 PM
Last post January 14, 2016, 09:49:54 AM
by fishreed
