Author Topic: Navionics Platinum Card-not working ??  (Read 13582 times)
Offline Llunker
  • Team Llunker
  • Team Llunker
    • Ultimate Lunker Fishing Forum
  • Unit(s): 997c SI
  • Software: 4.75
  • Accessories: SI with in-hull transducer as well
« on: March 14, 2010, 12:02:19 AM »
Ok guys while playing around with my unit at HOME(mind you i am at home and not in the boat) --i decided to place my 2010 south platinum card in the unit to see some lakes.
I dont see anything? normal mode or sim mode--nothing--i do see the navionics icon menu though with the settings for the card like chart overlay, platinum 3d, and 3d overlay but no maps.
Do i have to be outside actually hooked up to the boat with GPS to be able to use the Navionics card?
Silly question but I can't seem to find an answer on the web?
thanks for any help here guys
Llunker
El Grande Lures Field Staff
Offline George
  • Software: Always up todate
Re: Navionics Platinum Card-not working ??
« Reply #1 on: March 14, 2010, 10:22:40 AM »
Llunker
I live in Southern CA and have the 2010 S Platinum Card for Oklahoma and Texas.
First off you need a Gps hooked up and has to have located your current location otherwise you cannot get the map on your screen (at least that is what I found) and it must be in the advanced mode.
Go to the Chart drop down menu, then Chart Select, choice between Auto / NVB / Left (or Right) Chart Card.  I have my card in the left slot so I choose the Left Chart Card.
To look at various lake maps I use the (-) key until the area you want to see is viewed.  Then you scroll the cursor to the lake you want to look at and zoom in.  It is a little bit of a pain but it works.
If someone knows how to load specific lakes please advise, there must be an easier way.  Most of the time I use NavPlanner to look at the various lakes, this is a lot easier.
One of the problems with Navionics is they do not supply any documentation on how to use their card.
 George
« Last Edit: March 14, 2010, 10:26:58 AM by George »
Offline Llunker
  • Team Llunker
  • Team Llunker
  • Unit(s): 997c SI
  • Software: 4.75
« Reply #2 on: March 14, 2010, 03:53:08 PM »
well i finally got it to work.  and it does work in sim mode at home.  What a pain for getting around==always having to zoom in and out just to see where you are on the map.  --they should have a menu with all the lakes built in and be able to choose a lake to go to.
But i got it working
oh and BTW--do you leave the Chart Detail level=underwater---that way you can see in 3-d?
Offline George
« Reply #3 on: March 14, 2010, 04:04:19 PM »
Glad you got it working, I will have to try it.
If you use NavPlanner the lakes can be pulled up by the ports.  It is easier to navigate around on.
George
Last post January 02, 2012, 07:57:28 AM
by tommy29461
Last post July 02, 2013, 06:18:57 PM
by oz
Last post August 26, 2013, 08:52:36 PM
by maachuu
Last post September 17, 2013, 08:32:23 AM
by Rotus623
Last post September 21, 2014, 11:57:33 AM
by prov275
Last post January 08, 2015, 06:22:05 PM
by mustang99
Last post August 31, 2015, 08:47:09 AM
by chasin tails
Last post November 04, 2015, 10:17:51 PM
by gray6431
