Author Topic: navionics platinum + and way points  (Read 11659 times)
Offline chasin tails
  • Unit(s): 1198 cisi
« on: August 30, 2015, 08:21:44 PM »
Installed the new card and when I want to save a way point I get an error message I cannot write to the navionics card.  How do I set way points with this card. what am I missing.
Re: navionics platinum + and way points
« Reply #1 on: August 30, 2015, 08:46:50 PM »
Waypoints are written directly into the unit memory (not to the SD Card) ...
Screenshots are written directly to an SD Card ...
If you are getting an error message when you hit the "Mark" button ... Then you have "Screenshots" enabled under the "Accessories" tab in the Main Menu System ...
Pressing the "Mark" button with Screenshots enabled tries to capture a screenshot at the same time as marking a waypoint ...and because the only SD Card in the unit is a mapping card ...the unit doesn't want to write a snapshot to the map card...
Disable Screenshots under the "Accessories" tab so that pressing the "Mark" button only saves a waypoint to the internal memory ...
Or install a blank SD Card in the unit that a snapshot can be written to at the same time as saving a waypoint to the unit memory ...
« Last Edit: August 30, 2015, 08:51:01 PM by rnvinc »
« Reply #2 on: August 31, 2015, 08:47:09 AM »
Thanks Rickie, it makes sense to me now.
Last post January 02, 2012, 07:57:28 AM
by tommy29461
Last post April 14, 2010, 06:24:00 PM
by Wayne P.
Last post May 11, 2010, 03:15:42 PM
by Moose1am
Last post October 11, 2010, 09:40:47 AM
Last post January 09, 2012, 07:19:04 AM
Last post February 15, 2013, 09:28:31 PM
by crazyaboutcoues
Last post July 02, 2013, 06:18:57 PM
by oz
Last post August 02, 2013, 12:52:49 PM
by V Side Down
