Author Topic: how do you view the map you made  (Read 9665 times)
Offline basseyes
  • Unit(s): 999 si
« on: September 27, 2015, 11:02:23 AM »
New to stuff and i can't figure out how do you view the map i made after closing AC?    I'd like to look at the contour lines on the PC.   Surely i don't have to recreate the map each time.  Any help would be appreciated.
Offline CamoHunter
Re: how do you view the map you made
« Reply #1 on: September 28, 2015, 10:38:13 AM »
You just have to go under Tools -> Settings -> Change the background map from Lakemaster to AC.  That should do it.
Offline basseyes
  • Unit(s): 999 si
« Reply #2 on: September 29, 2015, 08:31:42 AM »
Ok thanks.   I'll try it.
Offline basseyes
  • Unit(s): 999 si
« Reply #3 on: September 30, 2015, 08:48:55 AM »
Well, I see the radio button to uncheck but can't find where to select AC.  What am i doing wrong?
Offline CamoHunter
« Reply #4 on: September 30, 2015, 09:14:15 AM »
Look at page 68 here:
http://www.humminbird.com/WorkArea/DownloadAsset.aspx?id=5727
That's what your Background Map settings page should look like.  Select "Custom Depth Data (AC)".
You need to have your ZeroLines SD card in the computer, if that's where you created your map.
Last post September 10, 2018, 08:02:14 PM
Last post June 27, 2010, 10:47:36 PM
by calli1
Last post August 30, 2010, 01:48:09 PM
Last post March 30, 2012, 04:37:41 PM
by alex
Last post May 10, 2013, 03:04:44 PM
by matt@reefmaster
Last post January 20, 2014, 03:31:45 AM
by crankin007
Last post April 06, 2014, 02:51:31 PM
by LittleGazoo
Last post May 06, 2017, 08:01:02 PM
by jachristensen3
