Author Topic: ONIX 8 SI depth reading in high speed  (Read 9312 times)
Offline simm128
  • Unit(s): ONIX8SI
« on: July 17, 2015, 07:01:49 PM »
I have problem using my original transducer to get normal depth readings with high speed.
but if I look on sonar screen then this screen shows almost correct depth (10-15 feet) (but depth numbers are shown 1000+feet).
also I have old 2D  transducer from Lowrance but as I understand I cant use it with Humminbird?
Re: ONIX 8 SI depth reading in high speed
« Reply #1 on: July 17, 2015, 07:17:10 PM »
See this ...
http://www.bassboathq.com/how-to-convert-lowrance-to-humminbird-shoot-thru-hull-transducer-for-high-speed-2d-sonar-1037/
To use this on Onix ... You would also need the AD1429 adapter because Onix is 14 pin and that Motorguide adapter is the #9 connector...
http://www.humminbird.com/Products/AD-1429/
If you are going to use a "shoot thru" along with the Onix "All in One" xducer you will also need the AS 14 SIDB Y cable ...
http://www.humminbird.com/Products/AS-14-SI-DB-Y/
« Last Edit: July 17, 2015, 10:17:27 PM by rnvinc »
Last post January 25, 2010, 09:46:54 PM
Last post October 30, 2010, 04:05:23 PM
by Mildog
Last post February 02, 2011, 08:52:54 PM
Last post January 27, 2013, 05:29:20 PM
by hvychev77
Last post February 19, 2013, 12:03:35 PM
Last post December 06, 2013, 08:07:02 PM
by JDX
Last post July 05, 2014, 06:41:00 PM
by Trout Bum
Last post June 20, 2015, 11:33:01 AM
by starkyb
