Author Topic: frozen screen  (Read 11243 times)
Offline tdh
  • Unit(s): HB798, 798 & Garmin 240
  • Software: 6.600, 4.750 & ?
  • Accessories: weather sense
frozen screen
« on: July 10, 2015, 11:11:57 PM »
798 hd si...
798 hd si...Both si and di screens are locked up. They worked for about 30 minutes, then froze with last picture showing. 2d, gps work fine. Any ideas? thanks
Re: frozen screen
« Reply #1 on: July 10, 2015, 11:25:08 PM »
Issues such as these are often times attributed to a low power issue ...
If you are sure there is no issue with your battery or the boat's wiring ... Try Restore Defaults ...
Also try rebooting into the Simulator by pressing the Menu button at boot up and selecting "Simulator" from the popup ...
Report back with results ...
Offline tdh
Re: frozen screen
« Reply #2 on: July 11, 2015, 05:13:39 PM »
Rickie,  Thanks for your quick response, but it will be a couple of days before I can get out on the water to try things out....I'll be back.
Thanks, tdh
Offline tdh
Re: frozen screen
« Reply #3 on: July 12, 2015, 02:11:15 PM »
Rickie,
Charged everything up last night. Went out this am...same thing, after 15 -20 minutes the di and si would freeze up. Used the default and BINGO everything works. Fished for a couple of hours and still works fine.
Thanks Rickie!!!!
tdh
Re: frozen screen
« Reply #4 on: July 12, 2015, 10:32:00 PM »
Rickie,
Thanks Rickie!!!!
tdh
This is good news ...
The only downside of the ability to use Restore Defaults is having to input your custom settings again ...
Last post May 28, 2014, 09:40:36 AM
Last post January 07, 2011, 08:04:11 AM
by cdub
Last post February 15, 2011, 07:34:11 AM
by kosmo
Last post March 24, 2011, 11:44:54 PM
by jorawil
Last post March 25, 2011, 03:30:51 PM
Last post April 08, 2011, 01:11:40 AM
by stillbear
Last post October 17, 2011, 04:15:35 PM
