Author Topic: 999ci black lines in side imaging  (Read 17139 times)
Offline progatorin4bass
  • Unit(s): 798ci hd si, helix 5 di gps
« on: June 30, 2015, 12:48:03 PM »
Just installed my 999 and took it out on the lake last week end and there are black lines in both sides of my side imaging. Also the images aren't as clear as I expected. I will add a image but it was captured while reviewing on humviewer not sure if that makes a difference but it looks pretty much the same
Re: 999ci black lines in side imaging
« Reply #1 on: June 30, 2015, 12:54:26 PM »
Picture of transducer placement
« Reply #2 on: June 30, 2015, 12:55:36 PM »
Snapshot of recording with humviewer
« Reply #3 on: July 01, 2015, 10:57:45 AM »
Black horizontal lines such as these (not matching left and right) are usually an indication that the xducer is not far enough down in the water for the specific scanning speed ... Bubbles are blocking some of the sound pulse ...
Either lower the xducer or slow down the boat speed ... And test ...
You may want to look into a L bracket from Transducer Shield and Saver to get the HDSI down farther into the water ... Below the bubbles ...
http://www.transducershieldandsaver.com/home/l-brackets
« Last Edit: July 01, 2015, 11:03:57 AM by rnvinc »
« Reply #4 on: July 01, 2015, 12:54:42 PM »
Thanks for your reply I will try that
Offline Todd Hendrick
  • Unit(s): 999 CI/HD/SI
  • Software: newest
  • Accessories: none
« Reply #5 on: August 28, 2015, 08:29:29 PM »
Just picked up new triton with 999 combo and this is the only picture i get on SI. Can someone please help?
« Reply #6 on: August 28, 2015, 11:07:35 PM »
Try Restore Defaults under the Setup tab ...
Can you post a pic of your xducer ...??
  • Software: newest
  • Accessories: none
« Reply #7 on: August 29, 2015, 11:54:04 AM »
I tried resetting defaults, no good. Here is a pic of the transducer.
« Reply #8 on: August 29, 2015, 12:21:36 PM »
That position should work for idle speed scanning (not high speed on plane readings) ...(I'm assuming your testing on the water - sonar does not work thru air) ...
Is there also a "shoot thru" xducer in the bilge connected with the AS SIDB Y cable in your setup ...??
If there is also a "shoot thru" xducer ...disconnect the AS SIDB Y cable and test the HDSI directly into the head unit and test on the water ...
If there is not an additional "shoot thru" xducer... Can you crosstest your head unit on some one else's xducer or their head unit on your xducer ..??
« Last Edit: August 29, 2015, 12:24:07 PM by rnvinc »
  • Software: newest
  • Accessories: none
« Reply #9 on: August 29, 2015, 02:53:02 PM »
I am testing in my driveway  :(. I thought it would atleast show something but I'm not very smart. I also don't have a shoot through. Now, it did the same thing on the water. Unfortunately I don't have anyone near me. I really appreciate your help!
« Reply #10 on: August 29, 2015, 10:51:14 PM »
Definitely the sonar won't give any readings thru air ...but you're saying you have the same image when testing on the water ...??
If you are indeed getting the same results on the water ... You may have a xducer problem ...and without another xducer to crosstest with ... You should call HB ... 1-800-633-1468
Last post July 02, 2011, 05:10:34 PM
Last post October 22, 2011, 07:01:20 PM
by jgollihar
Last post June 07, 2012, 02:20:38 PM
by rlazop2004
Last post January 20, 2013, 02:28:26 AM
by mike fish
Last post June 26, 2014, 06:18:58 AM
by Steve Schmidt
Last post July 15, 2016, 02:14:47 PM
by pat.gearhart@icloud.com
Last post October 25, 2022, 09:18:31 PM
