Author Topic: solix 12 G3 Mega+ side image wave lines  (Read 10592 times)
Offline jimf
  • Unit(s): 997ci si
« on: October 24, 2022, 09:15:42 PM »
I get this white wave lines on the left side of Mega+ Its doesn't show up on 800 Khz or 455 Khz. Only on the Mega+ I have a picture attached. I was thinking try to set the sharpens ?
Offline jimf
  • Unit(s): 997ci si
Re: solix 12 G3 Mega+ side image wave lines
« Reply #1 on: October 25, 2022, 01:42:59 PM »
What i did I turned the SI Sensitivity offset to -7 and the white wave lines went off the screen. If i turn the SI sensitivity offset the opposite way to say 6 or 7 the white wave lines come very close to the central of the screen.
Looks like if I turn SI sensitivity offset to -7 it gos away.
Is that what the SI Sensitivity offset is for ? Because it worked BUT i will see what it really looks like on the water when I go out again.
JIM
« Reply #2 on: October 25, 2022, 09:18:31 PM »
“SI Sensitivity offset” adjusts the left panel of the SI view if that left SI view is consistently brighter or darker than the right SI panel  ...
If there is not another unit running the same frequency (which can cause crosstalk interference) - try Sonar Restore Defaults or full Restore Defaults  ...
Last post March 01, 2011, 09:06:24 PM
by noisemaker
Last post April 29, 2013, 02:11:31 PM
Last post August 20, 2015, 12:54:42 AM
Last post August 30, 2017, 09:10:38 PM
by fshndude
Last post June 12, 2018, 06:06:11 AM
by Captain Cook
Last post March 05, 2019, 08:30:40 AM
Last post October 18, 2021, 09:34:16 PM
Last post November 06, 2023, 04:18:32 PM
by Jopple
