Author Topic: 999 transducer  (Read 2978 times)
Offline coldsteel
  • Unit(s): 798ci si combo
999 transducer
« on: June 29, 2015, 06:53:25 PM »
I just started installing new 999. The transducer is not tight on pin. Seems to be a lot of play even though all is tight. It will move a lot when trailering and I'm sure a lot when on the water. Is this normal? My old unit the transducer was solid in place. Thanks in advance.
Re: 999 transducer
« Reply #1 on: June 30, 2015, 11:17:46 AM »
It is normal for there to be a little play in the xducer movement ...
You can squeeze the metal ears of the bracket a little to take some of this play out ...
Any modification that clamps the xducer tightly reduces the effectiveness of the "kickup" design of the xducer/mount design ...
by Sonshine Fishing
by Brian37075
by jgcox6
by bobcoy
Last post May 02, 2014, 08:09:36 PM
by bobcoy
Last post January 27, 2015, 10:32:43 PM
by Fredfx21
