Author Topic: Mounting 898c SI Transducer On A DEEP-V Alum. Boat  (Read 28487 times)
Offline Dropshot
  • Unit(s): 898c SI
« on: March 09, 2010, 10:51:50 PM »
My new 898c si should be delivered tomorrow.  I should be able to get my boat out of storage in a week or so after more snow melts.  Just wondering on placement.   I have read that the motor will need to be raised enough so not to disturb the beam.  How far over from the motor would be a good location.  Thanks for any input.ila_rendered
Re: Mounting 898c SI Transducer On A DEEP-V Alum. Boat
« Reply #1 on: March 10, 2010, 07:48:02 AM »
for your boat you might try not more than 1/2 way from dead center.  There is a lot of posting on locations and you may have to try or experiment.  with the deep v you might not have as much issues as other shallow draft boats.  check thru the forum gallery and see what others have done.  Also check the forum for transducer location previous posts.  There is a search tab at the top right of the home screen to help in searching.  Most issues with transducer seems to be at speed above trolling speed.  Chuck
« Reply #2 on: March 10, 2010, 01:25:36 PM »
With a deep-vee hull I would go over even less than what Chuck said; try no farther than 1/4 of the distance from the motor to the side of the transom.  This will put the transducer farther down in the water which will help with it being an aluminum boat hull.  From that picture showing the 20HP motor hanging off the back I don’t think that you will have any high-speed depth readings issues.
« Reply #3 on: March 10, 2010, 07:29:30 PM »
I was thinking 1/3 the distance!  ::)  Anyway, here is where I would put it!
Offline Dropshot
  • Unit(s): 898c SI
« Reply #4 on: March 10, 2010, 07:43:51 PM »
Thanks for the info guys.  The 20hp motor is the largest hp allowed in the lakes in my area. ::)  I still need 2 feet of snow to melt and 12inches of ice before I can give her a try after I get it mounted.  Now that I got my unit I can't wait to give it a try. ;D
Offline raypla
  • Unit(s): 898 HD SI
  • Accessories: I-Link
« Reply #5 on: March 11, 2013, 07:41:05 PM »
 know this is old but it looks exactly like my boat.
How did the above location work out for you?
I have a deep V also but w/a 50 hp Merc and a right console steering wheel.  Am I going to be able to get high speed readings?
I'm going to be pairing a 898 HD SI w/a 55 lb Terrova I-Link, I am looking forward to much less controlling of the TM and more time fishing w/my two boys :)
« Last Edit: March 11, 2013, 09:25:36 PM by raypla »
16.5' Tracker Deep-V
50 hp Mercury
55lb Terrova I-Link
898 HDSI
Offline raypla
« Reply #6 on: March 13, 2013, 12:54:42 PM »
Some one must have some input on my question above  ::)
50 hp Mercury
55lb Terrova I-Link
898 HDSI
« Reply #7 on: March 13, 2013, 02:26:46 PM »
Ok, I'll take a shot:
Quote
Unknown until you test it. :-[
Every boat/motor combination/equipment/weight distribution is different.
If your transducer lifts up too far out of the water, YOU WILL NOT
get good high speed readings.  If it stays deep enough, YOU WILL
PROBABLY get good high speed readings.
The best thing to do is to get a transducer mounting plate and secure that
to your transom in the general area where you want to mount the transducer.
You only have to drill two holes to install the plate.
Then, experiment with time on the water, moving the transducder.
It may take awhile to find the very best spot.
Offline raypla
« Reply #8 on: March 13, 2013, 08:09:53 PM »
Alright, Thanks for the input.
From what I've been reading it looks like a delicate ballance between getting you transducer free from any obstructions/propeller turbulance and keeping it out of harms way.  Where I bring my boat often, the Hudson River, has a ton of debris in it.  You can be cruising up river see what looks like a 6" chunk of tree bark and you go by steering clear, observe the piece and it's a F'n 8' log!!
50 hp Mercury
55lb Terrova I-Link
898 HDSI
« Reply #9 on: March 14, 2013, 07:57:23 AM »
That's bad.
I hear that lowering the transducer will give better
high speed readings, but then the transducer is
more vulnerable to hitting something.
I fish the Potomac river some, and it too gets a lot of
floating debris.  I heard that a guy hit a freaking floating
dumpster.  Damaged his lower unit and his fiberglass boat.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #10 on: March 15, 2013, 12:41:40 AM »
I'm in the same position as others with the transducer well below the bottom of the hull.
It's just a matter of time before I whack something. POOF! $240. GONE.
Wish this poster would follow up on how he's making out with his idea.
May try be build something similar in the spring.
  http://forums.sideimagingsoft.com/index.php?topic=3067.msg17714#msg17714
               Mike
Last post April 06, 2009, 04:39:12 PM
Last post April 22, 2010, 05:37:23 AM
by jefi
Last post May 11, 2010, 09:15:16 AM
Last post August 22, 2010, 11:33:22 AM
by werethefugowee
Last post December 07, 2010, 10:13:41 AM
Last post February 20, 2011, 11:47:33 PM
by dubldown
Last post May 08, 2013, 02:13:32 PM
by BillM
Last post September 08, 2013, 09:21:24 AM
by CHOOhonets
