Author Topic: Re: Pontoon Boat transducer mounting  (Read 13659 times)
Offline AnglerDon
  • Unit(s): 998c si
« on: June 12, 2010, 03:24:02 PM »
I  have an Arcoa Pontoon Baot with a heck shaped pontoon (flat bottom) I want to mount the 998C SI transducer to the back bottom pontoon as it has a bracket there already. Anyone see a problem with that mounting or any suggestions on the mounting on this type of pontoon
Don
« Reply #1 on: June 12, 2010, 11:07:20 PM »
Don,
I am not familiar with this style pontoon.  Best bet would be to take some pictures of the mounting location showing straight on and from the side and with motor trimmed down.
This way we can take a look at the situation and give you better advice.
Offline AnglerDon
  • Unit(s): 998c si
« Reply #2 on: June 13, 2010, 09:28:03 AM »
Thanks Robert, I should recieve the unit in the mail this week and will be up at the  lake the end of the month. So will be able to take pictures then.
Here is a link to the pontton site. So you can get an idea of what they look like.
http://www.ercoa.com/hextoon_pontoons.htm
Don
Offline DCDiveRescue494
  • Unit(s): 997SCI
  • Software: 4.75
  • Accessories: none at this time
« Reply #3 on: August 09, 2010, 12:04:39 AM »
we have a 997sci side imaging sonar on our rescue pontoon,  we mounted on the right side back of the toon where the bracket is already welded.  we get great pics and no problems with that location.
  1989 tracker bass buggy
Offline werethefugowee
  • Unit(s): 997si
  • Software: Downimaging
  • Accessories: speed
« Reply #4 on: August 22, 2010, 11:33:22 AM »
On my pontoon boat I had an aluminum bracket welded on the back of the toon, centered on  the lowest point, and the transducer sits about an inch below the toon. No problems at all with turbulence of any kind.
Last post April 06, 2009, 04:39:12 PM
Last post March 15, 2013, 12:41:40 AM
Last post February 20, 2011, 11:47:33 PM
by dubldown
Last post April 10, 2011, 05:20:05 PM
by dubldown
Last post March 28, 2012, 03:53:26 PM
by depark1
Last post September 22, 2013, 12:49:28 PM
Last post March 30, 2015, 12:33:56 PM
by fshndude
Last post April 18, 2016, 11:34:34 PM
