Author Topic: ONIX Software Update  (Read 13295 times)
Offline fotoguy
  • Unit(s): ONIX10ci SI combo
  • Software: 2.300
  • Accessories: iPilot Link
« on: May 10, 2015, 08:38:14 PM »
Updated my ONIX to the new version 2.30, it updated just fine the only thing so far is when I am moving no matter if it is slow are fast the depth reading is off the charts.
Screen shots below:
Offline Trytoofish
  • Software: 2.0, 7.51,
Re: ONIX Software Update
« Reply #1 on: May 10, 2015, 08:52:40 PM »
I would check your transducer selection and frequency selected. It acts like you have no transducer connected or selected. I have seen depth jump around a bit on mine but only in shallow water. And switching max depth from auto to a depth a little deeper than i'm in, fixes that.after updating, if you restored defaults some of the selections change.
Try Too Fish  Forced To Work
Offline g dog
  • Unit(s): Onix 8
« Reply #2 on: June 05, 2015, 12:17:54 AM »
Mine is doing the exact same thing.  Did you find a solution?
Offline fotoguy
  • Software: 2.300
« Reply #3 on: June 05, 2015, 06:24:28 PM »
No, I did not fine a solution
Offline brisner
  • BER Custom Lure Painting
  • Unit(s): Onix 10 ci SI, 1158 DI HD
  • Software: 2.0, 7.530
« Reply #4 on: June 11, 2015, 11:37:38 AM »
Same here looks like another patch needed. Mine has been back to Humminbird four times now and need to go back again! Mine won't save data when recording after the last update.Okay
Offline fotoguy
  • Software: 2.300
« Reply #5 on: July 09, 2015, 06:16:49 PM »
Has anyone else had this problem?
Offline brisner
« Reply #6 on: July 09, 2015, 09:34:08 PM »
I had two units running at the same time one was my Onix and the other a 859 Sonar / GPS unit on sonar at the same time and got the high depth reading. Now when I run I shut off the sonar on one of the units. Power button, Sonar - Off. That fixed mine.
Last post July 04, 2014, 12:11:47 AM
by CarolC
Last post December 18, 2014, 07:33:13 PM
by johnbaker
Last post February 18, 2015, 11:48:46 AM
by brisner
Last post July 06, 2015, 12:29:32 AM
by bufordw
Last post April 01, 2016, 07:29:19 PM
by RonnieB
Last post April 21, 2016, 07:46:45 AM
by N9Phil
Last post August 01, 2016, 05:30:01 PM
by smallie690vs
Last post March 14, 2017, 08:53:17 PM
by Trytoofish
