Author Topic: Onix 10x update  (Read 9709 times)
Offline Vinniez520
  • Unit(s): 3 10" Onix
  • Software: 2.300
  • Accessories: 360
Onix 10x update
« on: April 20, 2016, 06:39:00 PM »
 Hey guys can the onix be updated other than the card slot? my card slot in either 1 or does not seem to be working?? so instead of sending back for a warranty repair and update can I do it another way.
       Thanks John
Re: Onix 10x update
« Reply #1 on: April 20, 2016, 10:09:23 PM »
I don't know of any other way of a user updating the ONIX except using the SD Card slot ...
Can you test the SD Card slots by trying to copy images from the internal memory to the SD Card ... ??
Or even try exporting Nav data to a SD Card ...
This will help determine if the SD Card slots are working correctly ...
Offline N9Phil
Re: Onix 10x update
« Reply #2 on: April 21, 2016, 07:46:45 AM »
If you haven't already restored to factory defaults, I would probably start there.  I would then go to Settings,Chart , and Humminbird chart card info and see if anything is listed. When you add a card it should show if it is a valid card or not.  Hope it works out for you.
Phil
by Nitro78
Last post July 09, 2015, 09:34:08 PM
by brisner
Last post April 01, 2016, 07:29:19 PM
by RonnieB
Last post March 28, 2018, 11:13:48 AM
by TAKFishing
Last post October 03, 2019, 01:05:53 PM
by Dgr57
Last post October 20, 2021, 12:09:26 AM
by RonnieB
