Author Topic: Is Di on an Onix from an XHS 9 HDSI 180 T Possible  (Read 17680 times)
Offline Trytoofish
  • Software: 2.0, 7.51,
« on: April 12, 2015, 05:47:05 PM »
YES. I didn't take the time to play with the settings much. But here is the proof.
Try Too Fish  Forced To Work
  • Moderator
Re: Is Di on an Onix from an XHS 9 HDSI 180 T Possible
« Reply #1 on: April 13, 2015, 08:47:10 AM »
When you took theses screen snapshots, what transducer did you have selected in the ONIX menu system TTF?
Offline Trytoofish
« Reply #2 on: April 13, 2015, 09:08:24 AM »
Greg  standard onix default . with di and 2d selected. si was off. this wasn't  plug and play  I made an adapter cable. Using the right si pezo pointing down fed to the di pins of the onix plug. 2d is coming from the universal sonar on the trolling motor. and the hdsi is on the trolling motor also.
  • Moderator
« Reply #3 on: April 13, 2015, 09:22:31 AM »
Ah, a little bit of EXPERIMENTATION!   ;D
« Reply #4 on: April 13, 2015, 10:27:56 PM »
Now that sounds like something I would do ...
Good job trytoofish...
Offline Trytoofish
« Reply #5 on: April 14, 2015, 06:49:02 AM »
What prompted this, is the Onix transducers have such a large cable it will not fit the grove in a Terrova trolling motor. running the transducer cable up the groove makes a nice neat install. Plus I already had an xhs 9 hdsi installed. I like the 2d/di combo up front. Minn kota needs to think about this factor in the future when designing trolling motors. I think the images i got with a little adjustment to settings will be  as good as i have seen from the onix hdsi/di transducer. ;D Rickie you were the inspiration to try this.
« Last Edit: April 14, 2015, 06:53:16 AM by Trytoofish »
« Reply #6 on: April 15, 2015, 12:18:43 AM »
Can you explain a little more about the adapter cable you made ... ??
« Last Edit: April 15, 2015, 12:20:20 AM by rnvinc »
Offline kosmo
  • Unit(s): 2 - 998 , 597hd/di
« Reply #7 on: April 15, 2015, 04:19:50 PM »
I like What u have done and understand why. I agree that u can get near the quality di with XHS 9 HDSI 180 T, if u were to rotate it were one si peizo were facing down.I have experimented with this
Offline kosmo
« Reply #8 on: April 15, 2015, 04:36:46 PM »
I have done this on a 998,with good results
Offline Trytoofish
« Reply #9 on: April 26, 2015, 11:41:17 AM »
Thanks Kosmo And Rickie
Here are a couple more from shallow water. I did some comparing of these to a 998 hd and composite DI this time out. these were much better. I was going to take some snapshots on the 998 hd but no sd card The 998 was on the console using an HDSi on the transom and the Onix on the bow trolling motor using an HDSi
« Reply #10 on: April 26, 2015, 11:55:50 AM »
Those are definately interesting ...
I wish work would slow down so I could find time to build new cables for my Onix ...
Dang job gets in the way of important experimentation ...!!
Offline Trytoofish
« Reply #11 on: June 04, 2015, 10:22:49 AM »
I experimented with the XTM 9 Wide Di 20 T yesterday.  Here are the results.  IMO Just as good maybe better than the HDSI!
« Last Edit: June 04, 2015, 10:27:54 AM by Trytoofish »
« Reply #12 on: June 04, 2015, 11:23:15 AM »
Cewlbeanz Craig ...
I'm liking what I'm seeing in your shots ...
I hope to be contacting that link you gave me soon so I can start building stuff for my experiments ...
Last post June 13, 2013, 11:05:36 AM
by Nitro78
Last post February 25, 2014, 12:13:35 PM
by silvercloud
Last post April 07, 2014, 09:20:19 PM
Last post November 13, 2014, 08:16:31 AM
by lcookie
Last post February 26, 2015, 02:17:59 PM
Last post March 23, 2015, 11:28:33 AM
by metalworx
Last post October 02, 2016, 11:45:52 PM
