Author Topic: onix nt  (Read 8741 times)
Offline metalworx
  • Unit(s): 2- 998c si
  • Software: 6.740
onix nt
« on: March 22, 2015, 08:54:21 AM »
This is for Humminbird Greg.  I currently run two 1198's networked together with ethernet.   I'm also running a as gps hs antenna and a tg w (think that's correct) temp probe in livewell.   If I switch to two Onix NT 10 SI units, can you tell me what all I will need for this new setup.   Thank you for your time!  Also, will older Navionics premium east map cards run in these units?
metalworx
« Last Edit: March 22, 2015, 08:56:04 AM by metalworx »
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
Re: onix nt
« Reply #1 on: March 22, 2015, 11:11:02 PM »
You will need the ONIX power cord with the temp/speed connector for livewell monitor and the ONIX GPS/nema cord to attach HS puck.  Ethernet cable  is the same.  Navionics chip should work.  Everything else should come with the units.
Re: onix nt
« Reply #2 on: March 23, 2015, 10:56:54 AM »
100% correct lcookie.  ;D
The PC-12-ST Power Cable will allow you to connect the TG-W to your new ONIX 10 NT SI unit and the AS-GPS-NMEA will allow you to connect the GPS-HS GPS Receiver (with Heading Sensor).  The Navionics Premium mapping cards will work as well.
Offline metalworx
  • Software: 6.740
Re: onix nt
« Reply #3 on: March 23, 2015, 11:28:33 AM »
Thanks guys for the info!
Metalworx
by Nitro78
Last post June 28, 2014, 02:25:09 PM
by CarolC
Last post January 31, 2014, 05:45:03 PM
by LittleGazoo
Last post April 07, 2014, 09:20:19 PM
Last post November 13, 2014, 08:16:31 AM
by lcookie
Last post April 12, 2015, 11:39:58 PM
by Brunswick
Last post February 29, 2016, 09:54:06 PM
