Author Topic: 360 mounting height question  (Read 15004 times)
Offline Jimmy B
  • Unit(s): Onix 8 SI Onix 8
  • Software: 6.3.0.0
  • Accessories: 360 Ulterra
« on: March 29, 2015, 10:20:43 AM »
Mounting 360 to transom, install says to mount bottom of pod at 8" above bottom of boat, makes it 2" too  high to get into my garage. Would like to mount 6" above bottom of boat, anyone mount lower than the 8" recommended.
Other thought was to use Clovis pins instead of bolts the quick removal for storage ? Any thoughts appreciated.
« Last Edit: March 29, 2015, 10:44:43 AM by butitta »
Re: 360 mounting height question
« Reply #1 on: March 30, 2015, 08:42:03 AM »
I believe that the tilt bracket for the Talon shallow water anchor will work with the 360 Imaging.  Call the Humminbird Customer Service folks to be 100% sure though.
Offline N9Phil
« Reply #2 on: March 30, 2015, 04:58:52 PM »
The Talon tilt bracket will work but humminbird also has a transom tilt bracket for the 360.  This is what I use and it works great.  I tilt it when I am trailering and when I get home I remove the 360 from the boat. here it is.  http://www.humminbird.com/Products/PORT-360-BKT/
Offline Jimmy B
  • Software: 6.3.0.0
« Reply #3 on: March 31, 2015, 09:55:44 AM »
Thanks for the info, ordered Minn Kota tilt bracket, will let you know how it works out.
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
« Reply #4 on: March 31, 2015, 09:49:23 PM »
The talon tilt bracket works.  I use mine to get into the garage.
Offline Jimmy B
  • Software: 6.3.0.0
« Reply #5 on: April 02, 2015, 08:33:58 PM »
Talon tilt brack worked great and bolted right up to 360
« Reply #6 on: April 03, 2015, 10:59:07 AM »
Tiled flooring in your garage...  :o
Color me envious!  :'(
Oh, the tilt bracket looks great too.
Last post March 06, 2011, 06:42:56 PM
Last post December 19, 2011, 02:34:43 PM
Last post November 05, 2012, 07:16:24 PM
by asm
Last post January 09, 2013, 01:09:30 PM
Last post May 20, 2013, 02:42:57 PM
Last post July 24, 2014, 11:11:43 PM
by Hennessyt
Last post November 15, 2016, 03:39:17 PM
by Baker11
Last post November 09, 2017, 08:32:56 PM
