Author Topic: Mounting Transducer question  (Read 13878 times)
Offline Mattk15
  • Unit(s): 797SI
  • Accessories: WeatherSense
« on: December 17, 2011, 05:17:00 PM »
Would like to know if I would be able to mount a transom SI transducer for my 797 SI unit that I just got. Can I make this work so that I can see the SI in both directions without interference with my setup since I do not have a jackplate? Here are some pictures and am looking at the compact SI transom transducer unless another is recommended. Thank you and here are some pictures of what I have to work with.
Can take more pictures if that would help.
Offline Double Digit
  • Unit(s): 998 c si...Navionics Platinum +
  • Software: 6.180
Re: Mounting Transducer question
« Reply #1 on: December 17, 2011, 10:11:42 PM »
The motor isnt gonna be a problem that intake screen might be in the way though...
Offline Mattk15
  • Unit(s): 797SI
« Reply #2 on: December 17, 2011, 10:18:36 PM »
Ok great. I plan on using one of those transducer mounting boards which is like 3/4" thick. Think with that all would be good? Also would the compact si transducer be my best bet for the 797? Thanks for the reply.
  • Software: 6.180
« Reply #3 on: December 17, 2011, 10:38:11 PM »
I'm not sure about that unit but keep checking back somebody will have the answer for you this forum is awsome and the people are great....Welcome aboard and good luck...
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #4 on: December 17, 2011, 11:54:39 PM »
I don't think the screen would be a problem since the transducer should be hanging below the bottom of the boat. Looks easy enough with that flat bottom boat.
Offline Mattk15
  • Unit(s): 797SI
« Reply #5 on: December 17, 2011, 11:57:43 PM »
Great, I just heard some had problems with the motor being in the way and only being able to shoot to one side, not having the other side available for the SI. Do not want that and was just making sure that will not happen with this transducer on my boat. Thank you.
Offline LocDown
    • Fishing Videos
« Reply #6 on: December 18, 2011, 12:19:32 AM »
Looks like a lot of clearance to me.
« Reply #7 on: December 19, 2011, 02:34:43 PM »
That Compact Side Imaging transducer only needs about five inches of clearance.  Even with the 0.75 inch mounting board it looks like you will have plenty of clearance.
Last post March 06, 2011, 08:22:58 AM
by troutfanatic
Last post March 06, 2011, 06:42:56 PM
Last post April 30, 2011, 07:02:34 PM
by djhoffman
Last post November 05, 2012, 07:16:24 PM
by asm
Last post January 09, 2013, 01:09:30 PM
Last post April 03, 2015, 10:59:07 AM
Last post November 09, 2017, 08:32:56 PM
