Author Topic: Custom Charts and Lake mapping FREEWARE  (Read 40084 times)
Offline l889
  • Unit(s): 798HDSI
« on: August 03, 2013, 06:18:37 AM »
Hi!
My name is John. I've written some software to do mapping of recorded HT tracks and generating depth maps using Humminbird echos. Some of you would know my software published in "Unofficial HB Forum" since last year. So I think it's time to say hello in this forum, and introduce my free software:
### HBTrackMapper ###
Using HBTrackMapper, you are able to map a lake from few recorded traces. The recording is done using your Humminbird and also it is possible to display the mapped chart on your Humminbird! All you need is some recorded tracks from your lake and this software.
Importing GPX KML and HT Files
- Load any number of GPX tracks or HT tracks recorded by your Humminbird.
- Add shoreline and island figures, drawn in Google Earth and exported to KML or GPX.
- You are able to set custom colors, which will result in nice images.
- Using the editing tools you could delete wrong recording points and merge multiple files to a big project. Save and load this project as an GPX file.
Prepare Mapping
- Interpolate with a very good algorithm values between the tracks and create a depth map. You will love it's extrapolation width which could be set to your needs. It is possible to get a nice map with just a few tracks with distances of more than 50m between.
- Setup custom discover width!
- Mapping is using all CPUs of your machine, so you'll get finished faster.
After mapping
- This is the mapped image!
ISO lines
- Now it's time to create an ISO style map. Setup the depth difference of each line and start it:
- After calculation you could export this file as an GPX to view on your Garmin GPS...
Exporting maps for Humminbird units
- Create an HT file of the ISO map to view it on your Humminbird while fishing!
Save as an HT-File to SD Card and upload to your Humminbird. It is also possible to upload via serial connection (please contact me for further instructions!).
- Have better fishing results with custom charts!
- Zoomed:
Using the free software "Blender" it is possible to render such nice images from a mapped lake...
Just set mapping color to black/white and map an image, save it as a heightmap and follow the instructions given in this guide:
how to make terrain in blender
Download here: http://www.lnx-ware.de/echotoolbox/HBTrackMapper_V10.exe
This is postcardware.
Please donate or write a postcard! Such projects will survive only when supported.
And hey! Didn't you save money and time when using free software? So please write me an postcard showing your region! Mail address provided via PM.
Please contact me via PM  for any problem solving or support.
Offline 4d-rock
  • Unit(s): 997c SI, 778c, 570
  • Software: 6.30
Re: Custom Charts and Lake mapping FREEWARE
« Reply #1 on: August 03, 2013, 11:22:23 AM »
Hey John,
Thanks for putting this together.
I've been playing around with some of the earlier versions since I got a Side imaging unit this spring.  However, I haven't really been able to get a good map out of it yet.  Once I add all my files (incomplete shorelines due to a big lake, as well as my tracks from the humminbird) I then try to interpolate.  When I do this, I get a black screen with the shorelines.  I played around a bit more, and the program thinks that the land side of the shoreline is actually the water, so it isn't creating the contours in the lake.  Is there a way to dictate what side of a kml line is the water side, and which side is the land side?
Thanks,
Adam
Offline l889
  • Unit(s): 798HDSI
« Reply #2 on: August 04, 2013, 06:18:53 AM »
Hi Adam!
Islands are detected by the program when they comply following conditions:
- closed island shape
- all islands are _inside_ the main shoreline
The second condition will create some problem, when you try to map a very very big lake, where you don't provide a closed shoreline... In such a case you should try to close the shoreline in any way (rectangular) to give the program an mapping canvas. Try the newer versions, there are a lot of improvements since prior releases.
Best regards!
John
Offline 4d-rock
  • Software: 6.30
« Reply #3 on: August 05, 2013, 11:47:05 AM »
Alright thanks for the suggestions John.
I will modify my shorelines accordingly and see how things go in the new version.
Offline 4d-rock
  • Software: 6.30
« Reply #4 on: August 12, 2013, 04:48:00 PM »
Well I was able to make an alright map from some of my recordings, though I will need to do some gap filling as there is a lack of data in some areas.
A quick question though.  Is there a way to either change the colour of the scale, or possibly shade between the lines based on depth (similar to what you see on navionics or lakemaster maps).
It would just be easier to visualize depths than the green shades that it defaults to.
Offline l889
  • Unit(s): 798HDSI
« Reply #5 on: September 01, 2013, 05:38:21 AM »
yes, click on the depth reading (0 m...max m) on the bottom bar next to the gradient, then there will pop up a color dialog. But that's only for the app. However, the color scale on the Humminbird couldn't be changed  :(
« Last Edit: September 01, 2013, 05:42:43 AM by l889 »
Offline lovehummin
  • Unit(s): 997C
  • Software: 4.750
« Reply #6 on: January 30, 2014, 03:10:36 AM »
Hello John.
Thank you very much ask me HBTrackMapper and Blender.
now I don't know How to paint Blender's 3D image(According to the depth gradation paint)
If you know it. Please ask me.
ks411vm@hotmail.com
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #7 on: July 31, 2014, 12:27:11 PM »
Any place you can still down load this from???
Offline l889
  • Unit(s): 798HDSI
« Reply #8 on: July 31, 2014, 04:12:29 PM »
please check first post for download link.
Offline sfw1960
« Reply #9 on: July 31, 2014, 07:51:12 PM »
Link didn't work earlier for me ~ TY!
Need some time to mess with it now!!
Offline gimez
  • Unit(s): matrix97 797
« Reply #10 on: January 22, 2015, 06:03:34 AM »
hello! i need some help with this software... i try to build a map and evrything goes right, but when i try to see the map in my humminbird 797 the tracks are all conected with lines, not  segmented tracks. i think this software build segmented tracks, or not? I'm doing something wrong?
some help please...
thanks
Offline brisner
  • BER Custom Lure Painting
  • Unit(s): Onix 10 ci SI, 1158 DI HD
  • Software: 2.0, 7.530
« Reply #11 on: January 22, 2015, 10:38:58 AM »
Does it work with the new Onix?
Offline Long Hair
  • Unit(s): LCR 2000, LCR 8000, Helix 5 SI GPS
  • Software: 7.260
  • Accessories: TM Transducer
« Reply #12 on: May 08, 2015, 05:51:27 PM »
Howdy, Does this program work with Helix 5? Windows 8.1 Pro? Is there a way to write the actual depths in numbers on the contour lines? Thanks
You can always make too much, work.
Offline Mars_Artis
  • Unit(s): Helix 5 G2 chirp SI
  • Software: 1540
  • Accessories: none
« Reply #13 on: March 26, 2018, 05:03:54 AM »
Anybody tested if HBTrackMapper maps can be used on HELIX 5 CHIRP DI GPS G2?
Offline Kenai
    • Confidence
  • Unit(s): 598, Helix MSI+ 9 G4N, Helix 7 CHIRP G3N
  • Software: v7.300, v2.930
« Reply #14 on: April 09, 2024, 03:04:59 PM »
In case, someone is still interested in this project. I'm still using HBTrackMapper_V20a. I have 598 unit. Currently, I'm planing to upgrade to Helix, and I'm also interested if someone can confirm this is still working on new units.
Offline Kenai
    • Confidence
« Reply #15 on: April 10, 2024, 10:27:22 AM »
And here is the last version of HB Track Mapper V2 http://www.lnx-ware.de/echotoolbox/HBTrackMapper_V20a.exe It seems all bugs are fixed and it works flawlessly.
Offline oschi
  • Unit(s): HELIX 9 CHIRP MEGA SI+ GPS G4, MEGA Live
  • Software: 2.800
« Reply #16 on: April 10, 2024, 05:46:21 PM »
nope, no ht files written
CreateHT: splitting dataset
CreateHT: #Points (total): 2988
Save Track: ISO 700 cm
Save Track: ISO 800 cm
Save Track: ISO 900 cm
Save Track: ISO 1000 cm
Save Track: ISO 1100 cm
Save Track: ISO 1200 cm
Save Track: ISO 1300 cm
CreateHT: iterate ===== 000 ======
CreateHT: n_wpt_total is 3477
CreateHT: n of IsoDataWrite 2988
WriteHTFileC:\Users\oschi\Desktop\000.ht
« Last Edit: April 10, 2024, 06:01:28 PM by oschi »
Offline Kenai
    • Confidence
« Reply #17 on: April 12, 2024, 03:08:56 PM »
Maybe it is because of Windows. I'm luckily still on win 7.
4 CPUs found
LoadGPXFile: Trying to open C:\Users\Kenai\Documents\mapa jazera\mapovanie jazera project V3.gpx
LoadGPXFile: Examining Track 09/24/17 11:34 AM
LoadGPXFile: GetMaxDepth is 1140
LoadGPXFile: Track has valid depth readings
LoadGPXFile: Removing all 0m readings
LoadGPXFile: Examining Track 09/24/17 9:51 AM
LoadGPXFile: Examining Track 09/16/17 JAZ2
LoadGPXFile: GetMaxDepth is 795
LoadGPXFile: Examining Track 09/24/17 8:03 AM
LoadGPXFile: GetMaxDepth is 1100
LoadGPXFile: Examining Track 09/16/17 JAZ3
LoadGPXFile: GetMaxDepth is 1080
LoadGPXFile: Examining Track 09/16/17 JAZ1
LoadGPXFile: Examining Track jazero.kml
LoadGPXFile: GetMaxDepth is 0
LoadGPXFile: Examining Track ostrov.kml
LoadGPXFile: Examining Track 10/11/17 7:47 AM
LoadGPXFile: GetMaxDepth is 1290
LoadGPXFile: Examining Track 10/11/17 10:12 AM
LoadGPXFile: GetMaxDepth is 1050
LoadGPXFile: Examining Track 10/11/17 11:26 AM
LoadGPXFile: GetMaxDepth is 1170
LoadGPXFile: Examining Track 10/25/17 11:37 AM
LoadGPXFile: GetMaxDepth is 1250
LoadGPXFile: Examining Track 10/25/17 8:14 AM
LoadGPXFile: GetMaxDepth is 1560
LoadGPXFile: Examining Track 09/28/18 6:20 AM
LoadGPXFile: Examining Track 09/28/18 12:24 PM
LoadGPXFile: Examining Track 10/03/18 3:45 PM
LoadGPXFile: GetMaxDepth is 1270
LoadGPXFile: Examining Track 10/05/18 12:59 PM
LoadGPXFile: GetMaxDepth is 1210
LoadGPXFile: Examining Track 10/10/18 1:22 PM
LoadGPXFile: GetMaxDepth is 1190
LoadGPXFile: Examining Track 10/15/18 12:25 PM
LoadGPXFile: Examining Track 10/22/18 12:32 PM
LoadGPXFile: GetMaxDepth is 1150
LoadGPXFile: Examining Track 11/03/18 12:43 PM
LoadGPXFile: GetMaxDepth is 1240
LoadGPXFile: Examining Track R00017-FullTransducerTrack
LoadGPXFile: GetMaxDepth is 1220
Interpolate: Working on 190847 samples
Interpolate: maxDontCareRadius is 0,000878632301464677
Interpolate: minDontCareRadius is 1,79312719410518E-5
Interpolate: #Tasks: 16
Interpolate: Start Thread: 0     108
Interpolate: Start Thread: 109     217
Interpolate: Start Thread: 218     326
Interpolate: Start Thread: 327     435
Add Thread: 436     544
Add Thread: 545     653
Add Thread: 654     762
Add Thread: 763     871
Add Thread: 872     980
Add Thread: 981     1089
Add Thread: 1090     1198
Add Thread: 1199     1307
Add Thread: 1308     1416
Add Thread: 1417     1525
Add Thread: 1526     1634
Add Thread: 1635     1751
CreateHT: #Points (total): 27680
Save Track: Shoreline
Save Track: ISO 100 cm
Save Track: ISO 200 cm
Save Track: ISO 300 cm
Save Track: ISO 400 cm
Save Track: ISO 500 cm
Save Track: ISO 600 cm
CreateHT: n_wpt_total is 19999
CreateHT: n of IsoDataWrite 19390
WriteHTFileC:\Users\Kenai\Documents\mapa jazera\test\000.ht
HTCOnvert: number of points to write: 19999
CreateHT: iterate ===== 001 ======
CreateHT: n_wpt_total is 8813
CreateHT: n of IsoDataWrite 8291
WriteHTFileC:\Users\Kenai\Documents\mapa jazera\test\001.ht
HTCOnvert: number of points to write: 8813
Offline Kenai
    • Confidence
« Reply #18 on: April 12, 2024, 03:14:13 PM »
I can try to make those HT files for you, if you want.
Offline oschi
  • Software: 2.800
« Reply #19 on: April 14, 2024, 02:00:25 PM »
Tried on Windows 7. Same error.
Offline Kenai
    • Confidence
« Reply #20 on: April 23, 2024, 01:46:06 PM »
What is the source of your data ? Could you send me a sample track in .gpx ?
Offline Kenai
    • Confidence
« Reply #21 on: April 23, 2024, 02:03:05 PM »
I just get info from HB support regard Helix Series about Color By Depth function.
They told me:
"... The Helix units only have the option to change the color of the track, but not by depth. This option was not brought forward from the older units to the newer units. ..."
However, there was so much confusion in that communication, I will be really happy if someone can confirm this by actually looking on his unit.
If it is really true. It is very sad how humminbird understand evolution and improvement. There was demand for improving color scale for this, and they not bother to even keep it, not to mention improve it.
I got bead feeling it was intentional killing of third parties mapping SW.
Devolution  :(
So the next unit will be most likely garmin.  :'(
Last post March 05, 2010, 02:44:55 PM
by Llunker
Last post April 10, 2010, 08:12:54 AM
by easysailor
Last post July 14, 2010, 12:12:25 AM
by benamen
Last post September 14, 2011, 08:03:43 PM
by gup72
Last post February 16, 2012, 08:36:35 AM
Last post April 30, 2012, 10:07:28 AM
by Shooter00
Last post March 31, 2013, 07:58:16 AM
by Rüdiger
Last post February 26, 2014, 09:35:00 PM
by WI Bad Bass
