Author Topic: Onix 10 SI newbee  (Read 10583 times)
Offline larryk
  • Unit(s): Onix10 si
  • Accessories: ipilot and 360 imaging
Onix 10 SI newbee
« on: March 17, 2015, 04:40:40 PM »
So I bought me a boat and put all the latest HB bells and whistles on it figuring I was going to be the new "Go To" guy for people wanting to know where the fish are at the local lake....... so I knew there was going to be a learning curve but I am stumped. My 2d is working ok and my 360 is working good now that I have moved the transducer where it will deploy lower that my propeller. (transom mount on floatation pod). But my screen is almost entirely black on my DI and SI. No matter what settings I try it really doesn't change. I figured even with default settings I should see something....... any suggestions for a newbee Thanks
Re: Onix 10 SI newbee
« Reply #1 on: March 17, 2015, 09:48:21 PM »
I don't have an Onix ..... but will try to help ...
Do you have the latest software update on the unit?   Have you called Humminbird customer service about your concerns?
You should be getting great SI and DI with the Onix.
Offline larryk
« Reply #2 on: March 17, 2015, 11:15:26 PM »
No on the latest download and have not contacted HB service yet. Figured I might get it figured out on my own......  or with a little help from my friends. I did get a low voltage alarm so I think I will try again with a full charge. Unless someone else might have had this problem.
« Reply #3 on: March 17, 2015, 11:37:57 PM »
There were a LOT of fixes in the 2.0 update for the Onix.....If you call customer service, that is the first thing they are going to tell you to do.
You will probably want to update the 360 at the same time.... There are some videos floating around showing the update process....One of them is here:  https://www.youtube.com/watch?v=oM1kds69gRg&feature=youtu.be
« Last Edit: March 17, 2015, 11:39:31 PM by Bob B »
Offline larryk
« Reply #4 on: March 18, 2015, 09:40:11 AM »
I understand what you are saying about the updates and I will be doing that. But I'm not convinced that is the problem. I should still be able to see the screen with outdated software.
« Reply #5 on: March 18, 2015, 09:57:04 AM »
You need to be calling customer service ..... We are going to be getting into prime spring fishing before long and you want to get it round tripped before that if it has to go back and get fixed....or talk to the dealer where you bought it.
  • Moderator
« Reply #6 on: March 18, 2015, 11:03:27 AM »
Install the latest software and if you are still having problems, post some pictures of the transducer mounting and some Screen Snapshots of what you are seeing on your ONIX unit.
Offline Trytoofish
  • Software: 2.0, 7.51,
« Reply #7 on: March 18, 2015, 11:09:13 AM »
When you update you will want to follow these to the T.
Try Too Fish  Forced To Work
Offline larryk
« Reply #8 on: March 18, 2015, 01:53:31 PM »
Thanks for all the suggestions guys. My boat is at the shop getting a cover made for it but when I get it back this weekend I will update software on everthing and see what happens next.
« Reply #9 on: March 18, 2015, 02:29:50 PM »
Maybe post some screen shots of what you are seeing and some Pics of your transducer location from a few angles .... as Greg suggested.
« Reply #10 on: March 18, 2015, 10:27:32 PM »
Did you check to see if it is in night mode?
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
« Reply #11 on: March 22, 2015, 11:26:46 PM »
Did you check the sonar settings to make sure the di and si beams were turned on?
Last post February 19, 2011, 03:33:42 PM
by Kevin
Last post January 26, 2010, 02:46:41 PM
by Jolly Roger
Last post May 07, 2014, 04:27:24 AM
by Nitro78
Last post June 28, 2014, 02:25:09 PM
by CarolC
Last post January 31, 2014, 05:45:03 PM
by LittleGazoo
Last post April 07, 2014, 09:20:19 PM
Last post November 01, 2014, 07:54:34 PM
by kosmo
Last post November 13, 2014, 08:16:31 AM
by lcookie
