Author Topic: Newbee with Humviewer and snapshots  (Read 15555 times)
« on: January 24, 2010, 02:33:59 PM »
I've just started playing with my new 1197 in Simulator mode and starting to try and learn the Humviewer app...
This relates only to snapshots because I'm sure I will have separate questions for the recordings also...
Even though I copied all 4 .PNG and all 4 .DAT files into my Humviewer folder (on my desktop) only the .DAT folders show up in the File/Open command of the Humviewer program...
I can view the .DAT files in the Google Earth link thru Humviewer...no problem...
Can I view the .PNG file snapshots in Humviewer...??
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
  • Accessories: Speed sensor
Re: Newbee with Humviewer and snapshots
« Reply #1 on: January 24, 2010, 02:59:52 PM »
No, the .png is a standard image format so there is basically nothing for HumViewer to show. Try to double-click/open the .png file. You should be able to view it with a standard image viewer.
As far as I remember you can also click on the waypoint shown in google earth and see the snapshot there.
Regards
Martin
« Reply #2 on: January 24, 2010, 03:41:55 PM »
Thanks Martin...
I have no problem viewing the .PNG files in Windows...
I've just begun learning your Humviewer program...so I'm trying to learn what it will/will not do....
So far everything in your program seems to be working fine and I can tell it is going to be a very valuable asset to myself and the SI community...
Thank you... not only for your great program...but, also for your personal support that you give with Humviewer....
Offline Kevin
« Reply #3 on: February 19, 2011, 03:33:42 PM »
I also have an 1197 and from what I understand from HumView is that it will only view recordings. I have no problem viewing the image in Windows, but I'm more interested in the tools provided in HumViewer for setting waypoints, measuring the size of objects, etc.
Last post January 26, 2010, 02:46:41 PM
Last post February 21, 2011, 12:00:49 AM
Last post August 21, 2012, 12:43:46 AM
by depark1
Last post September 23, 2012, 09:21:46 PM
by mrbyrongray
Last post March 03, 2014, 04:39:01 PM
by Rotus623
Last post March 22, 2015, 11:26:46 PM
by lcookie
Last post July 05, 2017, 06:27:00 AM
by Mark Saikaley
Last post June 04, 2019, 08:12:27 PM
