Author Topic: Minn Kota Terrova w/Ipilot install  (Read 16532 times)
Offline HookonFishN
  • Unit(s): 798C SI/998C SI
  • Software: 5.7
« on: March 08, 2015, 05:55:36 PM »
Im currently running a798 and 998. I just ordered  the Terrova 112 w/link. I need to know if I need to buy any other cables to link it to my units to get the  most out of my tm. Also is anything need to use it with lakemaster other than a card of course.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Minn Kota Terrova w/Ipilot install
« Reply #1 on: March 08, 2015, 08:33:45 PM »
Hook. You will need an ethernet adapter cable for the 788 is it is to be hooked to the link. the 998 already has the connector that will plug into the cable that comes with the link. If you are to have both units and the link all networked together the you will also need the ethernet switch and an additional ethernet cable. Bob
Note: your 788 needs to be ethernet capable. (788 HD)
I just noticed you show 5.7 for software. you will need newer software than that for the link.
« Last Edit: March 08, 2015, 08:35:51 PM by bobcoy »
Offline HookonFishN
  • Software: 5.7
« Reply #2 on: March 09, 2015, 04:10:04 AM »
bob I have the 798 hd unit and 998 its been a couple of years since I been on this site but my software for both my units are updated as of 03/05/15 but my profile on this site has not I need to that. I already have the 798 &998 networked together so is all I need is the eithernet switch? When you say switch do you mean 5 port eithernet switch that I have seen on line?
Offline bobcoy
« Reply #3 on: March 09, 2015, 07:04:35 AM »
Yes on 5 port ethernet switch. Just a reminder, you need to hook 12v power to the ethernet switch. Have it hooked up so you can power it off. It draws current enough to drain your battery in 2 to 3 weeks if not powered off. I used one of the aux circuits so when I turned off the master switch it would turn off the 5 port switch. Bob
Additionally you will need a 2nd ethernet cable(both units need a separate cable)
« Last Edit: March 09, 2015, 10:42:56 AM by bobcoy »
« Reply #4 on: March 09, 2015, 09:40:16 AM »
I still don't understand why HB calls this network hub a "switch" ...
Offline N9Phil
« Reply #5 on: March 09, 2015, 09:58:56 AM »
Ricki,  here might be your answer.
https://www.youtube.com/watch?v=eMjpNuBRjk4
Offline HookonFishN
  • Software: 5.7
« Reply #6 on: March 09, 2015, 02:48:42 PM »
Thanks for your response Bob im just trying to make sure i have all the hardware when my unit arrives.
« Reply #7 on: March 10, 2015, 05:40:52 PM »
And this finally makes sense now ...
Thanks for that link Phil ...
Last post March 16, 2010, 10:08:29 AM
Last post February 29, 2012, 12:18:14 AM
by bft
Last post April 23, 2013, 11:41:13 AM
by rocketman2008
Last post May 06, 2013, 05:03:04 PM
Last post March 26, 2014, 10:05:10 PM
Last post May 04, 2017, 10:14:53 PM
by burgersb
Last post March 28, 2019, 12:23:59 AM
Last post April 01, 2020, 08:56:46 AM
