Author Topic: HDSI install on Minn Kota Powerdrive V2  (Read 13131 times)
Offline erocks4u
  • Unit(s): 1198 c si / 1198 c si
  • Software: 6.420
  • Accessories: Weather sense , gps , Ipilot
« on: May 05, 2013, 08:01:07 PM »
I have searched this forum and others and could not find pictures of a successful install of a HDSI XHS 180T, onto a Minn Kota Power Drive V2. So with the information gathered from various sites I’ve set out to install mine, using a Transducer shield and saver bracket. I had to do a slight modification to the bottom of the TSS bracket to fit tighter against the fin of the V2 I also glued a shim under the TSS to allow the transducer to be closer to the fin and away from the propeller. I’ve also attached a bungee cord close to the head and to the transducer cable leaving about 14 inches of slack in the transducer cable to allow the head to turn 360 degrees; this is also to keep the transducer cable taut to stop the cable from flopping around.
Questions:
1-   Will this set-up work?
2-   Will I get interference or blockage from the fin or prop?
3-   Anyone with better mounting ideas?
4-   I also unscrewed and removed the US2 cable from the head unit to allow the new transducer cable to slide easier with in the large coiled cable. Will this be a problem?
Al G
Re: HDSI install on Minn Kota Powerdrive V2
« Reply #1 on: May 06, 2013, 05:03:04 PM »
1- Yes
2-  No
3-  None from me.
4-  You will have to test it on the water to see.  There may be trolling motor interference and there may not be.
Last post March 16, 2010, 10:08:29 AM
Last post February 01, 2012, 12:48:25 PM
Last post February 29, 2012, 12:18:14 AM
by bft
Last post June 18, 2012, 01:29:05 PM
Last post November 17, 2013, 09:15:46 AM
by bemof
Last post March 09, 2014, 11:08:49 AM
by bobcoy
Last post March 26, 2014, 10:05:10 PM
Last post March 10, 2015, 05:40:52 PM
