Author Topic: shoot through Hull vs outside Hull- 788ci HD Di  (Read 11547 times)
Offline TheSavant
  • Unit(s): 788ci HD DI
« on: March 08, 2015, 12:22:36 PM »
I mounted my 788ci HD DI transducer to shoot through hull- manual and guys at HB said it would work fine, followed instruction, used their epoxy, etc.
These are some of the images I am getting- pretty sure I'm looking at standing timber, but the images just don't look clear enough to me.  Am I asking too much of this unit?  I was expecting to see "trees" not lines of dots..
Should I reconsider transducer placement?  If I do move it to outside the hull, am I going to get those pretty images that I see posted everywhere on the site  ;D
Thanks in advance-
Keith
Re: shoot through Hull vs outside Hull- 788ci HD Di
« Reply #1 on: March 09, 2015, 12:13:53 PM »
If you mounted the transducer correctly, there should be very little difference between an inside-the-hull mounted transducer and a transom mounted transducer.
Do you have a Screen Snapshots of the above trees?
Any chance that you could cross-test with someone else that has a Humminbird DI model unit?
Offline TheSavant
« Reply #2 on: March 09, 2015, 04:10:44 PM »
All I have are the above screenshots from humViewer. I can screenshot some examples the next time I am out.  I Don't know of anyone offhand to cross test my unit- but I will ask around.
It's encouraging that there should not be much difference. I will also try some different adjustments and see if it improves the clarity.
Thanks!
Last post April 14, 2010, 02:45:32 PM
Last post June 27, 2010, 12:04:16 AM
Last post March 13, 2011, 05:47:57 PM
by lolar3288
Last post March 29, 2012, 10:08:32 AM
Last post October 30, 2012, 01:51:28 PM
Last post September 12, 2014, 09:58:18 AM
Last post February 20, 2015, 04:04:47 PM
Last post April 14, 2020, 09:51:55 PM
