Author Topic: 997c si simulator keeps reloading  (Read 8869 times)
Offline sblatt
  • Unit(s): 997c si gps & 596 hd di
« on: January 30, 2015, 10:04:36 PM »
So I'm trying to pass time in the winter and play around with the  humminbird at the console. I go from the main menu into simulator, and after about 15-20 seconds, it goes to the loading screen and back to the main menu. Has anyone experienced this before? Any ideas and or solutions. I would love to be able to mess around with the settings in the garage. I'm running software version 6.300. Thanks for the help
Offline N9Phil
Re: 997c si simulator keeps reloading
« Reply #1 on: January 31, 2015, 07:49:30 AM »
What are you using for a power source?   I had that problem a while back and I went with a 2 amp power source and it solved the problem.  If your power source is not able to handle the load then these units will freeze up, re boot and do all kinds of strange things.
Phil
Offline sblatt
« Reply #2 on: January 31, 2015, 08:27:02 AM »
It's ran straight to the cranking battery with an inline fuse. Not sure of fuse size, but it only reloads in simulator mode. If I go into normal operation it'll run fine
« Reply #3 on: January 31, 2015, 08:47:57 AM »
Just to try something.   disconnect the GPS and the sonar transducers....or anything thing else connected. chuck
Offline sblatt
« Reply #4 on: January 31, 2015, 09:42:29 AM »
So to unplug everything, I need to go in the plug and pull out transducer cable and gps puck cable correct?
« Reply #5 on: January 31, 2015, 11:12:37 AM »
Yes, try that .   chuck
Last post May 14, 2010, 10:08:45 AM
Last post February 23, 2012, 08:36:21 PM
by depark1
Last post March 22, 2012, 05:03:12 PM
by Ggw2000
Last post August 14, 2014, 09:57:06 PM
Last post October 29, 2014, 07:40:28 PM
by Fly 1
Last post November 06, 2014, 05:42:47 PM
by Fly 1
Last post December 10, 2018, 01:20:09 PM
by Fresnoron
Last post April 06, 2019, 06:36:15 PM
