Author Topic: Navionics Card in Simulator mode ??  (Read 9574 times)
Offline Ggw2000
  • Unit(s): 798ci hd si
« on: March 22, 2012, 02:25:33 PM »
I just purchased a 798ci HD SI that is going to be put on new boat in a few weeks. I powered up the
unit in simulator mode just to make sure it turns on and to play with things.
I ordered a Navionics hotmaps premium east card and see that it was delivered today :). Can I access
the card after inserting it in unit when using simulator mode? If so does it matter if i'm inside the house
or not as there would be no GPS inside house and I don't think the GPS is even active in simulator mode?
Thanks, Gerry
Offline Shooter00
  • Unit(s): 798c SI 788ci HD
Re: Navionics Card in Simulator mode ??
« Reply #1 on: March 22, 2012, 02:36:42 PM »
I'm using a NV premium east and the chart works in simulator mode.
You just have to cursor to the location you want to look at,there's a setting to save your last looked at location so when you turn the unit on again it will go back to the same location...
Offline Shooter00
« Reply #2 on: March 22, 2012, 02:43:00 PM »
Forgot to mention if you do not have a transducer hooked up you need to manually go to simulator in the start menu if you want to save any settings and have the unit remember them.
Without a transducer hooked the unit will go to simulator as the default startup and in this mode the unit will not save any settings.
Offline Ggw2000
« Reply #3 on: March 22, 2012, 05:03:12 PM »
Thanks for the quick response. I will give it a try!!!
Gerry
Last post May 14, 2010, 10:08:45 AM
Last post April 12, 2011, 01:13:52 PM
Last post January 18, 2012, 04:29:24 PM
Last post February 23, 2012, 08:36:21 PM
by depark1
Last post February 23, 2013, 10:33:35 PM
by busterboy2238
Last post August 14, 2014, 09:57:06 PM
Last post December 10, 2018, 01:20:09 PM
by Fresnoron
Last post April 06, 2019, 06:36:15 PM
