Author Topic: Humviewer questions.  (Read 7700 times)
Offline bubbacolson
  • Unit(s): 385ci di 598ci hd si
  • Software: 6.110
  • Accessories: none
« on: January 20, 2015, 02:25:26 PM »
I just downloaded humviewer 86 and when I take a snapshot it only shows the left side of the image. How do I set to show both sides. Attached pics
Re: Humviewer questions.
« Reply #1 on: January 20, 2015, 04:38:38 PM »
Place your cursor on the picture. Right click, select View, select SI Both...  Chuck
Offline bubbacolson
  • Software: 6.110
  • Accessories: none
« Reply #2 on: January 20, 2015, 06:00:44 PM »
Chuck, I do have it set on si-both and you can see both on the screen in humview but when you click on save snapshot it only takes a pic. of the left side. Thanks
« Reply #3 on: January 20, 2015, 06:35:28 PM »
wow, don't know.  It works ok on my viewer.  Hmmmmmmmmm  Chuck
« Reply #4 on: January 20, 2015, 11:34:39 PM »
Interesting ...
The image you posted above ... Is this a PC "screensave" using the screensave button on a Windows keyboard ... Or is this a posting from the image ".png" that was saved on your PC ...??
Offline bubbacolson
  • Software: 6.110
  • Accessories: none
« Reply #5 on: January 21, 2015, 10:44:07 AM »
This image was made by humview, I stopped the recording and when to top right File and chose save image, it ask if you want to hide gps then it saves the image as a jpeg.  Attached is one taken in 3view.
« Reply #6 on: January 22, 2015, 08:43:19 AM »
You might want to uninstall humviewer and then reinstall.  If you stopped the playback and choose top/right you should have only seen the SI scan.  The picture you posted is SI, DI and TrackPlot usually found in 3 view.  it also looks like the 3 view standard screen has the top left selected at DI and not the default 2D.
Last post April 08, 2010, 02:51:31 PM
Last post May 09, 2010, 10:20:50 PM
by parole05
Last post February 18, 2011, 07:25:20 AM
by gofission
Last post May 09, 2011, 12:15:41 PM
Last post June 13, 2011, 01:43:00 PM
by Fishton
Last post November 08, 2011, 12:56:58 PM
Last post January 22, 2013, 04:16:17 AM
by Rüdiger
Last post August 10, 2014, 11:08:10 PM
