Author Topic: 998si transducer placement on a 519  (Read 6099 times)
Offline luke
  • Unit(s): 998
« on: January 16, 2015, 04:33:19 PM »
My transducer is mounted on the offset drivers side on my
ranger 519. If I get above an idle the image goes away. I do use a jackplate. Where should I mount this so I can use my 998si properly
Re: 998si transducer placement on a 519
« Reply #1 on: January 16, 2015, 05:09:09 PM »
Here is some Ranger installation info ...
http://www.bbcboards.net/humminbird-sonar-gps/172974-ranger-boats-installation-images.html
SI works best at idle speed ...
That's not saying it cannot be used at higher speed ... But getting the HDSI xducer in clean bubble free water at higher speed is difficult ...
Most bass boat installations usually opt to mount a XP 9 20  (2d only) in the bilge as a shoot thru and connect it to the head unit with the AS SIDB Y cable ...(along with the XHS 9 HDSI 180 T) ...
This allows high speed depth readings (from the XP 9 20) and allows mounting the more expensive XHS 9 HDSI 180 T higher on the transom for protection against damage from hitting something in the water ...
« Last Edit: January 16, 2015, 05:11:19 PM by rnvinc »
Last post June 21, 2011, 09:17:45 AM
by edwardpic
Last post March 20, 2012, 01:51:04 PM
by Brian37075
Last post August 16, 2012, 03:38:08 PM
Last post November 21, 2013, 07:54:40 AM
by freezerfiller
Last post July 13, 2014, 03:56:55 PM
by squam
Last post September 10, 2014, 12:16:32 PM
Last post May 02, 2019, 08:09:22 AM
