Author Topic: White spots on image  (Read 14190 times)
Offline palajam
  • Living afloat
    • Charts- Special Interest Group
  • Unit(s): 898cx si
  • Software: 7090
  • Accessories: none
« on: January 04, 2015, 02:00:21 AM »
I am getting white spots on my images. Any solutions please.
Pat
Re: White spots on image
« Reply #1 on: January 04, 2015, 02:51:42 PM »
It appears that your target is casting a shadow and the white images in the shadow area are things sticking up behind and above the target..   Chuck
« Reply #2 on: January 04, 2015, 05:47:21 PM »
I concur with Chuck on the possibility ...
Just for clarification if we are looking at the same "white spots" ... Can you edit the image in a drawing program and circle the "white spots ...??
« Reply #3 on: January 04, 2015, 11:51:09 PM »
I think the spots may be over the whole screen, but are difficult to see except in the darker areas.
It is probably some kind of electrical interference.  Have you tried systematically turning everything off?  Bilge pumps, trolling motor, radios, etc.    Is the main motor running when you see the spots?......are the spots there all the time?
Offline palajam
  • Living afloat
  • Unit(s): 898cx si
  • Software: 7090
  • Accessories: none
« Reply #4 on: January 05, 2015, 05:02:30 AM »
Thank you for the feed back. I will try out your suggestions. Are there electrical filters available?
Pat
« Reply #5 on: January 05, 2015, 02:54:18 PM »
After looking at your picture again I see the single white dots you are talking about.  This seems to be some sort of interference or a problem with the sonar. Do you see the spots when running sonar? do you see the spots only on recording sand playback..?
Offline palajam
  • Living afloat
  • Unit(s): 898cx si
  • Software: 7090
  • Accessories: none
« Reply #6 on: January 05, 2015, 03:11:08 PM »
I see the dots on both. Today I started a series of test to identify and eliminate interference. Are there any filters available?
Pat
« Reply #7 on: January 05, 2015, 04:52:37 PM »
The first step is to determine the source.....Interference can be picked up by the transducer, it can be on the power source, it can be picked up by the transducer.
The way to eliminate it will be different depending on the source.
You could try just drifiting and watching the SI and systematically turn off everything else....including the main motor.
Humminbird customer service is the best resource for eliminating interference.  If you know the source before you call them you will be ahead of the game.
« Last Edit: January 05, 2015, 04:53:57 PM by Bob B »
Offline palajam
  • Living afloat
  • Unit(s): 898cx si
  • Software: 7090
  • Accessories: none
« Reply #8 on: January 25, 2015, 02:52:48 AM »
I have now solved my white spot problem. by changing the power input. I also found that when my engine revs over 1500 I experienced interference on the starboard channel. So by staying below 1500 revs I get perfect images. Thank for all the help
Pat
« Reply #9 on: January 25, 2015, 02:08:48 PM »
Glad to year you have it resolved......Thanks for the feedback, it will help others.
Last post November 10, 2009, 05:56:30 AM
by FuzzyGrub
Last post August 30, 2010, 02:55:22 AM
Last post January 04, 2011, 09:56:58 PM
by Carl
Last post May 03, 2011, 05:59:04 PM
Last post July 01, 2011, 03:22:10 PM
Last post May 31, 2012, 08:59:52 PM
by rookiejd
Last post January 29, 2015, 03:06:47 PM
Last post May 21, 2015, 10:47:51 PM
by Tamnud
