Author Topic: 1197s and ethernet  (Read 7044 times)
Offline onebadcat
  • Unit(s): 1197, 1197
  • Software: 4.700
  • Accessories: Interlink, WeatherSence
1197s and ethernet
« on: January 03, 2015, 07:28:59 PM »
I am adding a 3rd unit to my boat. Will all the ethernet stuff work with the 1197s? The switch and cables?
Re: 1197s and ethernet
« Reply #1 on: January 06, 2015, 11:07:11 AM »
What are you meaning by “all the Ethernet stuff” and “The switch and cables”?
The 1197 cannot use/share resources as well as say a new 1199 unit but it does have some Ethernet capabilities.
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Unit(s): 1197c SI, 1198c SI, 360, 899
  • Software: Latest Versions
  • Accessories: AutoChart, Humviewer, ChartSelect, HBPC
« Reply #2 on: January 06, 2015, 01:27:57 PM »
You can share transducers, gps and waypoints.   I  have 1198, 1197 and a 899.
Offline onebadcat
  • Software: 4.700
« Reply #3 on: January 07, 2015, 12:22:36 PM »
I want to share waypoints and an aux temp between an 1197, 1197, and 1158.
« Reply #4 on: January 07, 2015, 12:40:14 PM »
Should not be a problem.
You will need the 5-Port Ethernet Switch (AS-ETH-5PXG) to connect all three together.
Offline onebadcat
  • Software: 4.700
« Reply #5 on: January 07, 2015, 12:41:29 PM »
Correct. Thanks Ill get it all together. Thanks
Offline onebadcat
  • Software: 4.700
« Reply #6 on: January 21, 2015, 08:43:04 PM »
Having trouble getting the Aux Temp shared over the network. 1197s are running 6.310 and the 1158 is running 6.900. I can share waypoints and transducer just not temps.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #7 on: January 22, 2015, 07:56:03 AM »
I have an 1197 and 1198 networked. The temp can be shared if you select the same temp on the network tab with both units. My 1197 is 6.64 thoughand 1198 using the latest(7.09). Not sure that will make a difference or not. Bob
« Last Edit: January 22, 2015, 08:03:33 AM by bobcoy »
Offline bobcoy
« Reply #8 on: January 22, 2015, 08:11:40 AM »
When I first started messing with network settings I found out there was a newer ethernet manual than I had. The manual number ended with a "2". Much more helpful with newer features. Bob
Last post February 09, 2011, 06:58:53 AM
by FuzzyGrub
Last post March 18, 2011, 03:21:13 PM
Last post June 27, 2011, 11:23:29 PM
by RzorbackAngler
ethernet
Started by conm 798c SI
Last post March 05, 2012, 08:30:07 PM
Last post October 20, 2012, 03:00:08 PM
by lcookie
Last post February 08, 2013, 10:25:53 AM
by Gator
Last post March 16, 2013, 04:55:39 PM
by Jim Jack
Last post July 30, 2014, 03:28:23 PM
by sfw1960
